SRS light on RSX
My SRS light stays on in my '02 base RSX, its not the fuse, and i dont know what else it could be, because i can obviously tell that my airbags havent deployed. Gimme some of your ideas on what it could be.
This is very strange. I have the 2005 RSX and the day I drove it off of the lot, the passenger side airbag light was on. I took it back to the dealer and as soon as I pulled into the parking lot it turned off. I've only seen the light once since then... sorry... I just had to share.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mexateck »</TD></TR><TR><TD CLASS="quote">This is very strange. I have the 2005 RSX and the day I drove it off of the lot, the passenger side airbag light was on. I took it back to the dealer and as soon as I pulled into the parking lot it turned off. I've only seen the light once since then... sorry... I just had to share.</TD></TR></TABLE>
was there someone in the pass seat? If so, it's normal. the airbag turns off depending on the passengers position...
is the "red" srs light constantly on? if so, you can try to reset it to see whether it helps. you can also try to check all the connectors to make sure they are not loose.
Similar thing happened to me in my 05 RSX Type S. I started it up one day and the SRS light didnt turn off. I just turned the car off, started it again and it went away. Is the RSX known for this???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">If its with the 3/36k warranty take it to the dealer and have it warrantied.</TD></TR></TABLE>
I would do the same ... warranty
its the way the passenger is sitting. read the owners manual it explains it
Yup if the passanger is leaning to the right or the driver is leaning to the left for a certain period of time the air bag disables itself.. My SRS light is on as well but its because I replaced my factory steering wheel....OH welll..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuckin19’s »</TD></TR><TR><TD CLASS="quote">Yup if the passanger is leaning to the right or the driver is leaning to the left for a certain period of time the air bag disables itself.. My SRS light is on as well but its because I replaced my factory steering wheel....OH welll..</TD></TR></TABLE>
same here
same here
search for srs reset. eg_nezay has a write up. i havent tried it myself though. that or go to the dealer. to clear the passenger side airbags, just sit correctly in the seat
there are two lights related to the Supplementary Restraint System. do not confuse the two.
the red "SRS" light incidcates a problem with the airbag system. if your car is still under warranty, take it to the dealer. be forewarned, they will give u the shpiel about not placing electronic devices around the passenger seat.
the yellow "side airbag off" turns on when the sensors detect that an object is in the deployment path of the passenger side airbag. typically this is your passenger leaning on the door handle. if the side airbag were to deploy while your passenger is seated like this, they would suffer a broken arm, at the very least.
DK4200
Mar 4, 2006 02:29 AM
