EVER BOUGHT A BAD....................................?
Old Mar 27, 2005 | 03:25 PM
88cerx's Avatar
Default EVER BOUGHT A BAD....................................?
OK went to AUTO ZONE to get rebuilt integra rear calipers and put the conversion on...
was able to take it for a ride and seem like the pass side caliper is not working (took hard turn in sand to see if inside tire would lock up ) the only side that would was the driverside one the i pulled the e-brake to do that TEST and then again just the driverside tire would lock up and not the pass side BUT when i jack it up and try to spin w/ e-brake up and hitting the breaks i cant move the wheel at all there is definatly NO AIR IN THE LINES (blead them profously!) could i have gotten a bad caliper or
thanks for you info please help fast
Old Mar 27, 2005 | 03:32 PM
sr20de2's Avatar
Default Re: EVER BOUGHT A BAD....................................? (88cerx)
Sorry if this has already been answered but do you have the correct proportioning valve on?
Old Mar 27, 2005 | 03:36 PM
88cerx's Avatar
the prop valve should have nothing to do wit it the prop valve just adds more pressure to both rear wheels the stock one should still put the same amount to both the BOTH should still lock up on the stock prop valve
Old Mar 27, 2005 | 04:03 PM
bagpipe goatee's Avatar
i've heard horror stories of rebuilt parts from stores like that, especially checker, but i'm sure autozone is bad too.
Old Mar 27, 2005 | 04:26 PM
91 HONDAsaurus rex's Avatar
Default Re: (bagpipe goatee)
hows the adjuster on the e brake. check the adjustment on the caliper or the e brake cable itself.
Old Mar 27, 2005 | 07:07 PM
88cerx's Avatar
Default Re: (91 HONDAsaurus rex)
the e-break cable seems fine i adjusted to almost perfect but i dont know of an adjustment on the caliper can you explain??????
Old Mar 27, 2005 | 07:09 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88cerx &raquo;</TD></TR><TR><TD CLASS="quote">the prop valve should have nothing to do wit it the prop valve just adds more pressure to both rear wheels the stock one should still put the same amount to both the BOTH should still lock up on the stock prop valve </TD></TR></TABLE>
actually, the proportioning valve is cross sectional, not front and back...
Old Mar 27, 2005 | 07:15 PM
88cerx's Avatar
Default Re: EVER BOUGHT A BAD....................................? (crxgator)
c'mon is it really i could have sworn it was front and back . can you tell me a little more about it
Old Mar 27, 2005 | 07:29 PM
deftones0817's Avatar
i say bleed it one more time just to be sure.
Old Mar 28, 2005 | 12:02 PM
88cerx's Avatar
Default Re: EVER BOUGHT A BAD....................................? (deftones0817)
tryed it again w/ no difference any more info will help or should i try a new caliper
Old Mar 28, 2005 | 12:10 PM
EJ2-Fluffy's Avatar
Autozone isn't that bad. If you think the caliper went bad, return it for a brand new one from autozone. They will replace it.
Are you using the correct proportioning valve?
-Jon
Old Mar 28, 2005 | 12:12 PM
EP3_05's Avatar
As far as autozone being bad they really aren't. I have had good success with their rebuilt parts. In fact I just replaced my master cylinder with one of their rebuilt ones a couple of weeks ago. If you think it is bad exchange it for another unit.
Old Mar 28, 2005 | 01:07 PM
LSvtec03's Avatar
Default Re: EVER BOUGHT A BAD....................................? (91civic)
yeah.....like i'm going to buy brand new oem calipers....
reman $ &gt; new $
reman calipers &gt; used
Old Mar 28, 2005 | 01:11 PM
88cerx's Avatar
Default Re: EVER BOUGHT A BAD....................................? (LSvtec03)
ya its raining here in ct so i will try to swap tomorrow
Trakhor
Dec 20, 2007 06:35 PM
dyu626
Honda Motorcycles
12
Sep 26, 2007 08:54 PM
govtec
Mar 15, 2005 12:48 PM
RKV
Mar 6, 2003 10:09 PM
Andrea_Aunie
Nov 16, 2002 01:13 PM
