type r swaybar
I think you can use the same size endlinks you have now. Upgrading from 14mm to 22mm doesn't require a change in endlink size and I doubt that the JDM swaybar requires different endlinks.
oh ok- cuz i have it on the car but i havent tried to fit the endlinks yet but it looks like they wontbe long enough... ill check it out today. i definatly need new bushings though. i was thinking energy suspension cuz thats what i have in the rest of my car. will the new 23 mm bushings fit in my stock endlinks?
the endlinks are not affected by sway bar size, supposing you have a '94-'01 Integra. i reused my stock end-links w/ my ITR sway bar. the 23mm bushings don't go anywhere near the end links. if you want adjustable end links, look to Function-7. they have infinitely-adjustable links. just make sure you reinforce your subframe good. don't want to rip through the frame of the car.
alright cool thanks- i thought the bushings that go through the holes in the ends of the endliks were of a smaller diameter than the typer r but ill take another look ( i have the 23mm idk if there is any difference than the 22mm) - nice car too btw looks alot like mine
