230+whp and Street Traction?
Old Mar 27, 2005 | 01:36 PM
asubennett's Avatar
Default 230+whp and Street Traction?
Ok Folks, what suspension set ups have you guys found to be most effective at gaining traction on your street car.
I currently have Type R rear LCA's and Tein HA's. Other than that there is not much. Tires are crappy Nitto Neo Gen's. (Worst tire ever)
Anyhow, I have zero traction in first or second gear regardless of how I take off or what speed I am traveling. Thanks for any input. No Traction on FWD and fast revving motors= NO FUN.
Old Mar 27, 2005 | 02:50 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: 230+whp and Street Traction? (asubennett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">No Traction on FWD and fast revving motors= NO FUN. </TD></TR></TABLE>
I know this...
Old Mar 27, 2005 | 03:05 PM
b19coupe's Avatar
Detune your car and traction won't be an issue
Old Mar 27, 2005 | 03:14 PM
asubennett's Avatar
Default Re: 230+whp and Street Traction? (b19coupe)
But that's no fun..... On a side note, I will be neptuned this upcoming Saturday. I am excited to see some of it's features up close and personal since you can't see them anywhere other than your local authorized dealer... No jab intended HRTuning... :-)
Bump for some more suspension advice.
Old Mar 27, 2005 | 03:27 PM
TURBOFTW's Avatar
up for a guy who cant drive for crap.... j/k the car rips...we though it was the clutch hahahaha.......
p.s- go back to work...
Old Mar 27, 2005 | 03:34 PM
asubennett's Avatar
Default Re: 230+whp and Street Traction? (h22dude)
lol, it just seems to unreal for the motor to be revving THAT fast.... But again, help me with some effective suspension mods.
Traction Bar and what else....
Old Mar 27, 2005 | 03:37 PM
TURBOFTW's Avatar
your tein's are fine there way stiff, traction bars will be a plus, as well as some GOOD tire and i think u will be happy....or u can try frame locks some say they work some dont, i have read some articles about this frame brace...
http://i15.ebayimg.com/03/i/03/24/31/01_1_b.JPG
Old Mar 27, 2005 | 03:46 PM
asubennett's Avatar
I wonder how much that piece weighs..... Hey why don't you adjust my Teins while your out there instead of surfing the net slacker. j/k Man it sucks being at the office on Easter.
Old Mar 27, 2005 | 03:56 PM
Honda_Tengoku's Avatar
I know u have been around for a while and prolly already know this and has been discussed tons but... LSD, traction bars, and personally if its that bad, I would run BFG drag radials on the street. If u dont want to run those fast wearing tires then run the falkien azenis sports. good luck man.
Old Mar 27, 2005 | 04:22 PM
asubennett's Avatar
Default Re: 230+whp and Street Traction? (Honda_Tengoku)
Thank you kindly sir. I have an OEM LSD, 4.7 final drive.
Maybe I can sacrifice turns with a pro drive spool. :-)
Is it possible to stuff some of these under the front fenders?
http://www.mickeythompsontires.com/strip.html CLICK ON ET STREET
Old Mar 27, 2005 | 04:30 PM
TURBOFTW's Avatar
-ET streets
- Traction bars
- that under brace, i dont think it weighs much it costs around $50
Old Mar 27, 2005 | 04:59 PM
sik_sol's Avatar
B A N N E D
theres always wider, up sizing in tires?? that would sacrifice acceleration cause of rotational mass, but it couldnt hurt with grip at all....?
Old Mar 27, 2005 | 05:17 PM
TURBOFTW's Avatar
Default Re: (sik_sol)
i think im going to get the bolt loose pray for me...and hey earlier i just put the gas in for you on my way home...if i would have known u were maken me pay for it i would have left it i just thought u needed gas for work....But no problem either way.
Old Mar 27, 2005 | 05:23 PM
rodimus's Avatar
Default Re: (h22dude)
what is the size/kind of rims/tires you are running.
Old Mar 27, 2005 | 05:59 PM
asubennett's Avatar
Default Re: (EVOL)
My bad on the gas thing. I put in $15 for you. Either way. It will cancel out the Xylene purchase you made for me. :-)
Evol: My PM's are broken. Rota GT-3, 16x6.5, 205/40/16 Neo Gen's.
Old Mar 27, 2005 | 07:21 PM
rodimus's Avatar
Default Re: (asubennett)
maybe get some falken azenis 215/45/16
although i do think 205/40/16 looks better in the wheel well on a civic hatch, gotta see what's more important to you.
Old Mar 27, 2005 | 07:37 PM
TURBOFTW's Avatar
Default Re: (EVOL)
TRACTION for sure, the car is a track car driven on the streets once and a while...i just took it for a drive right now and i punched it in second and roasted them... poor car maybe we should drive it on slicks with skinnies on back j/k
Old Mar 27, 2005 | 07:45 PM
Suprdave's Avatar
Get some big drag radials...225x50x15....
Old Mar 27, 2005 | 08:28 PM
mosteceg's Avatar
You should opt for a l-con traction bar omni coilover shocks and some urathan rear trailing arm bushings and your car will hook up great
Old Mar 27, 2005 | 09:27 PM
h22John's Avatar
I just put some azenis rt615's on my wifes car and it has ALOT better straightline grip than the old rt215................John
Old Mar 27, 2005 | 09:42 PM
Kendall's Avatar
Fat Bradstard is running about that much power with a 4.9 FD. He has absolutely nothing resembling traction.
Old Mar 28, 2005 | 08:24 AM
asubennett's Avatar
Default Re: (Kendall)
Yeah it sucks for the street. Hopefully some big drag radials will do the trick. Thanks for the suggestion Superdave.
Old Mar 28, 2005 | 09:52 AM
goforbroke's Avatar
MEAT PATTY
16x6.5 on the street, its not even 7" wide and you have 16's. You definitely need something wider then that.
But like Kendall said <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Fat Bradstard is running about that much power with a 4.9 FD. He has absolutely nothing resembling traction.</TD></TR></TABLE>
The video says it all
Old Mar 28, 2005 | 10:00 AM
99-DC2's Avatar
have you tried a camber correcting kit like omnipower or skunk2? i'm assuming your car is lowered substantially and i think you will get better straight-line (overall) traction if you're able to correct your camber to near factory settings... when I put in the skunk2 camber kit for my DC2 and had it adjusted near factory camber specs the straightline traction was improved dramatically...
Old Mar 28, 2005 | 08:18 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Ok Folks, what suspension set ups have you guys found to be most effective at gaining traction on your street car.
Anyhow, I have zero traction in first or second gear regardless of how I take off or what speed I am traveling. Thanks for any input. No Traction on FWD and fast revving motors= NO FUN. </TD></TR></TABLE>
What do you use for tunning? Consider launch control, and find the sweet spot. Like for my car, anything above 2500RPM spins out while anything below 2200RPM will bog. So I set mine for 2300RPM. Depending on condition of the streets, my tires will spin just a little, grip, and just launch my car.
