Best way to stop faster
Old Jan 25, 2002 | 10:13 PM
garados's Avatar
Default Best way to stop faster
I have a 95 GSR sedan and I want to be able to stop more quickly. I'm thinking about new pads and SS brake lines. Will that help at all? Or should I go with a new big-brake 4 piston caliper kit from Wilwood? Thanks.
Old Jan 25, 2002 | 10:22 PM
obd1canobie's Avatar
New User
Default Re: Best way to stop faster (garados)
If stopping on the street is a problem, slow your *** down.
If stopping on the track is a problem, then I'd start with the pads and S.S. lines
Old Jan 25, 2002 | 10:23 PM
89civicdx's Avatar
Hawk Hp+ pads, good fluid ,braided lines and a good bleeding should make you happy.The willwoods are overkill...unless you race, do you race?
Old Jan 25, 2002 | 10:27 PM
89civicdx's Avatar
Default Re: Best way to stop faster (89civicdx)
nevermind
Old Jan 26, 2002 | 08:31 PM
Gasoline Fumes's Avatar
I'd start with better pads and tires.
Old Jan 26, 2002 | 11:42 PM
FitCRX's Avatar
Default Re: Best way to stop faster (Gasoline Fumes)
Find nice thick wall!!!
Old Jan 27, 2002 | 12:39 AM
Heat Rave R's Avatar
Default Re: Best way to stop faster (FitCRX)
drag parachute and air-brakes!
Old Jan 27, 2002 | 09:20 AM
Lsos's Avatar
If you can now lock 'em up, then it will ultimately come down to your tires.
I imagine weight reduction and lowering the car would make some difference as well.
Also, look into changing the brake bias. My old car felt like the rear tires were doing much less than they could have been.
[Modified by Lsos, 6:22 PM 1/27/2002]
Old Jan 27, 2002 | 01:41 PM
BoM's Avatar
BoM
Default Re: Best way to stop faster (Lsos)
learn to downshift.
Old Jan 27, 2002 | 02:56 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Best way to stop faster (BoM)
4 bangers do not offer significant exhaust braking. We downshift to get back into the powerband, not to slow down.
Warren
alwaysoverkill
Nov 21, 2005 06:12 AM
stRodda
Oct 16, 2005 10:44 PM
eargrub
Jun 22, 2002 11:49 PM
Propulsion
Apr 1, 2002 07:40 AM
bus stop
16
Jun 29, 2001 04:13 PM
