GSR: 4 door and 2 door B-pipe: same size?
i thought that the 4-door was about 2" longer than the HB...you could make the exhaust fit but you'll have to cut some of the b-pipe
i'm not sure but i remember hearing that the b-pipe was the difference in most exhaust for different trims....
well i was assuming he was gonna use the gsr 4-door exhaust on his gsr 2-door..meaing that the only difference would be the length of the b-pipe since all integra's i believe have the same rear section...i'm not sure if you meant it wouldn't fit as in the way all the curves were made or if it wouldn't fit because it was too short or long....
the gsr has a shorter header and cat than the LS, so they make the b-pipes for gsr cat-backs longer
yes it will fit, and the muffler should fit to
XL8 si - "WTF you talkin' about willis!!!" don't answer what you have no clue what you are talking about! An LS/ITR exh. WILL FIT '00-'01 GSR coupe
what year is the 4dr exh. system you're talking about 94-99 or 00-01? the B pipes are different - I know that 00-01 4drGSR midpipes will ONLY fit 00-01 4drGSR - I am almost positive the same stands for 94-99 4drGSR of course I think it could be cut to fit - pls clarify does he wanna put this on a civic HB or integra GSR coupe?
EDIT sorry I am rather grumpy this morning
[Modified by 2000-4DRGSR, 7:32 AM 1/26/2002]
ummm KLN 4drs have a longer axle-back section
yes it will fit, and the muffler should fit to no it won't
[Modified by xlr8 si, 7:07 PM 1/26/2002]
<<the gsr has a shorter header and cat than the LS, so they make the b-pipes for gsr cat-backs longer>>
So this means if I plan on doing any (Integra) VTEC head or complete engine swap into my LS, I wouldn't be able to use my catback exhaust I have now? My idea to get around this is just to make a straight pipe that'll fit the gap and replace the factory cat with it. Would this work?
Then again I might just skip the engine or head swap and turbo this LS motor I have now...maybe I should get my car on the road first.
[Modified by Sleepy186, 8:24 PM 1/26/2002]
actually, the ONLy difference between a 2 door muffler and a 4 door muffler is the length of the TIP ONLY! The 4 door muffler have a 4" longer TIP only! I have an ITR mufler in my GSR SEDAN. It bolted right up with NO MODIFICATIONS.
