JG Sheetmetal IM + RPM Service TB install
Old Mar 27, 2005 | 04:47 AM
CRXEE8's Avatar
Default JG Sheetmetal IM + RPM Service TB install
I was about to install my JG IM and RPM Service TB when I found out that there were no where to install the IACV, brake booster and fast idle thermo valve. How do you guys hook this up?
First I thought the fast idle thermo valve would fit into the two holes to the left on my IM but it does not fit. What are these 3 holes for?
Thanks
Old Mar 27, 2005 | 06:50 AM
b19coupe's Avatar
Default Re: JG Sheetmetal IM + RPM Service TB install (CRXEE8)
Those three holes are for vacuum ports; you need to buy the fittings. Brake booster, PCV, and the FPR. You are correct about the IACV and thermo valve. Those are not used.
Old Mar 27, 2005 | 06:54 AM
CRXEE8's Avatar
Default Re: JG Sheetmetal IM + RPM Service TB install (b19coupe)
Thanks Todd...
Do you have a pic how you hooked it up?
Old Mar 27, 2005 | 07:07 AM
b19coupe's Avatar
Don't have pics now, sorry. And I don't have the manifold right now (loaned it out)so I can't take any.
Have you asked Jeff about this? He is usually pretty helpful.
Old Mar 27, 2005 | 07:15 AM
CRXEE8's Avatar
Yeah I will try and ask Jeff when he has replied to two other mails I send him.
Old Apr 4, 2005 | 02:03 AM
rev limiter's Avatar
correct me if i am wrong but isn't the fitv suposed to hook up to your TB ???
Like this :
That is gsr tb with fitv and the next picture is without fitv (newer year) that's why i have a gst tb with fitv and bored out by max bore to 64 mm. Because i like to have good cold start up in the winter. It is important to us obd0 guys haha.
and some more with fitv pics
Old Apr 9, 2005 | 04:30 AM
CRXEE8's Avatar
Default Re: JG Sheetmetal IM + RPM Service TB install (rev limiter)
Well the RPM Service TB is not made for the OBD0 FITV so I can't use my old FITV. I found out I had a OBD2 IACV with FITV included from my CRV engine. I will be using that and make an adaptor plate like rice4life did with his DIY ITB setup. I will ditch the PCV and use the fitting for the IACV instead. Btw. I found the fittings a my mashine shop who does a lot of US stuff.
CRV IACV:
IAC adaptor plate (https://honda-tech.com/zerothread?id=947796)
drglude
May 19, 2014 02:04 PM
ViZ
Jan 16, 2011 02:05 PM
dylokjai
Jun 10, 2008 05:29 AM
Mach69
17
Nov 23, 2005 07:01 PM
BryonC17
Jul 9, 2004 12:16 AM
