CTR VS ITR PISTON in a GSR
Old Mar 27, 2005 | 01:06 AM
irave4pho's Avatar
Default CTR VS ITR PISTON in a GSR
Which piston will pull more HP?
I own a 98 GSR.
My Goal is to beat a S2000 sTock
Plans:
skunk 2 valve springs/retainers
skunk 2 big cams
CTR or ITR PISTONs
Type R trannie or JdM GSR trannie. (any that has LSD built in)
What Else do anyone can suggest.
Thanks for the info.
Old Mar 27, 2005 | 01:21 AM
sheepey's Avatar
u dont need "built" block to beat one of those...or even touching the block..
Old Mar 27, 2005 | 03:07 AM
reactiondc2's Avatar
Default Re: (sheepey)
race gas will be needed with ctr pistons especially if you run a gsr head....try some p30 pistons instead
Old Mar 27, 2005 | 03:09 AM
Default Re: (reactiondc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irave4pho &raquo;</TD></TR><TR><TD CLASS="quote">Which piston will pull more HP?
I own a 98 GSR.
Plans:
skunk 2 big cams
CTR or ITR PISTONs
</TD></TR></TABLE>by the way what stage are "skunk 2 big cams"
Old Mar 28, 2005 | 05:33 AM
rodimus's Avatar
get the type r tranny over the jdm gsr tranny.
gearing is way better.
i know personally
just get jdm itr pistons. you'll be at roughly 11.5:1.
you're in cali, any compression that's higher on a daily driver is vulnerable to ping.
Old Apr 3, 2005 | 09:57 AM
fullteg's Avatar
Default Re: (EVOL)
HEY I HAVE A GSR WITH CTR PISTONS IN IT WHERE SHOULD BE MY COMPRESSION IN THE GAUGE 250,260,270,280, IF U CAN GET BACK TOO MY THAT WOULD BE COOL MY E MAIL IS BOUNC00@AOL.COM AND IF ANYONE ELSE KNOW U CAN HIT ME UP 2
Old Apr 3, 2005 | 10:41 AM
redlseg's Avatar
Default Re: (EVOL)
how can u tell the difference between usdm and jdm itr piston?
Old Apr 3, 2005 | 10:50 AM
VALET dude's Avatar
Default Re: (95eg6allmotor)
JDM=P73 00
USDM=P73 AO
Old Apr 9, 2005 | 05:54 PM
Anti-Drama Queens's Avatar
think the jdm has like .2 higher compression than the usdm itr pistons
Old Apr 9, 2005 | 08:27 PM
vtec y0's Avatar
Default Re: (mr_ducksauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_ducksauce &raquo;</TD></TR><TR><TD CLASS="quote">think the jdm has like .2 higher compression than the usdm itr pistons</TD></TR></TABLE>
Learned something new today
Old Apr 10, 2005 | 05:32 AM
Kidnkorner's Avatar
Default Re: (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">get the type r tranny over the jdm gsr tranny.
even the 99-00 transmission will have better gearing than the GSR. i believe the transmission code for it is the S80. but i dont remember.
Old Apr 10, 2005 | 08:56 PM
aron0903's Avatar
i have ctr pistons in my gsr and there is no pinging here. tuned with hondata and s2s2 on the way. id go with the ctr's just hope u have 93 octane where u live. u dont have to use racing fuel to have str pistons. good luck with the setup.
Old Apr 11, 2005 | 12:39 AM
THEUSED's Avatar
JDM ITRS will yeild 11.5:1 I thought it was 11.3:1
and I also thought p30s yeild 11.6:1, both in a GSR
Im still trying to decide which to get
gsrpedro
Jun 12, 2008 02:15 PM
RedTegGsr95
Apr 21, 2004 10:00 AM
Drian
Feb 22, 2004 09:24 PM
slogsr
14
Dec 7, 2003 08:58 PM
deez nuts
34
Feb 12, 2003 03:25 AM
