suggested fuel pressure?
Old Mar 26, 2005 | 10:49 PM
Cryojenik I's Avatar
Default suggested fuel pressure?
I have a honda prelude.. and it has a fuel pressure regulator on it.. im just curious as to what it should be running..the previous owner upgraded it a lil bit.. intake and full exaust sys..could someone answer my question please?
Old Mar 26, 2005 | 11:12 PM
Mike K's Avatar
Default Re: suggested fuel pressure? (Cryojenik I)
anywhere between 160-180psi should be sufficient.
jk
try 40psi. then adjust it from there..
Old Mar 27, 2005 | 02:18 AM
Default Re: suggested fuel pressure? (Mike K)
so it should be reading around 40psi..then? i was googling for this information like a ***** and the only thing i found was some guy saying i should be at like 55-58 if you've upgraded airflow.. but im sure my air fuel guage will tell me how well im running right? .. sorry i've never tampered with the fuel sys of a car before so i juss wanna make sure this kid before me didn f things up...ill tune it to 40 and see what happens if im running too low ill be looking at what kinds of indications?
Old Apr 10, 2005 | 03:21 PM
BLUE EH3's Avatar
Help we my pennies
whats a good pressure for a Bmotor?
Old Apr 10, 2005 | 07:50 PM
87sivtec's Avatar
^^^Waaaay too vague.
Need some specifics for both of the engines above. And you should use a wideband to get an actual airfuel reading.
Old Apr 12, 2005 | 06:31 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (87sivtec)
b20
b16
b18
Old May 23, 2005 | 08:27 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (BLUE EH3)
Old May 23, 2005 | 08:36 PM
LSVTEC 91 Civic's Avatar
Banned
Generally speaking, 40psi is usually a good starting point for a stock motor with I/H/E...
I run my fuel pressure at 46psi @ idle
Old May 24, 2005 | 03:32 PM
Quitripin's Avatar
Default Re: suggested fuel pressure? (BLUE EH3)
oem spec is 45-55psi b series
Old May 24, 2005 | 05:01 PM
chameleon's Avatar
Default Re: suggested fuel pressure? (Quitripin)
43.5 is what most injectores are rated at.
Old May 26, 2005 | 03:44 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (LSVTEC 91 Civic)
i was at 45psi and iwas runnin lean( i pulled my plugs) now im up at 55psi i will pull my plugs in after in 2weeks
Old Jun 21, 2005 | 11:17 AM
d15civ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Generally speaking, 40psi is usually a good starting point for a stock motor with I/H/E...
I run my fuel pressure at 46psi @ idle</TD></TR></TABLE>
is the 40psi generally speaking for any d-series?
for the basics im running the usual i/h/e. when i bought my fpr and gauge it was pushing 42psi and seemed to be running very rich, i could quite a bit of excess fuel.
i was told to drop it down to 30psi but now it feels under powered.
jdm d15b sohc vtec
crappy toms motorsport CAI with K&N filter
2.5" ss exhaust
crappy obx 4-2-1 header (gota sweet deal so s'all good, upgrading to dc in near future).
just wondering a suggested (safe) fuel pressure.
and if it matters, i have choices of 87,89,91,93,94 octane.
help me out.
Old Jun 21, 2005 | 12:07 PM
Jayboy's Avatar
Default Re: (d15civ)
When u guys are giving these numbers, are u doing it with the hose on or off?
Old Jun 21, 2005 | 01:18 PM
gsrious's Avatar
Default Re: (HollywoodEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HollywoodEH2 &raquo;</TD></TR><TR><TD CLASS="quote">When u guys are giving these numbers, are u doing it with the hose on or off? </TD></TR></TABLE>
the vacum line has always has to be off my friend.
Old Jun 21, 2005 | 05:30 PM
d15civ's Avatar
Default Re: (gsrious)
doing it with the vaccum off.
ive read on here tho in a few threads that you should pinch it,
Opo
Jan 11, 2007 11:58 AM
imskatencrzy
Mar 31, 2006 07:57 AM
NY-Trizz
Apr 18, 2003 02:26 PM
NZ Vtec Weapon
Feb 12, 2003 11:13 PM
