Stripping Paint off Wheels.
Old Mar 26, 2005 | 07:25 PM
fillup's Avatar
Default Stripping Paint off Wheels.
Whats the easiest wasy to strip paint off of wheels? The aircraft paint stripper isnt cutting it. (spray on) The wheels were sprayed with automotive paint and clear btw, not rattle can spray paint. thanks.
Old Mar 27, 2005 | 05:30 AM
Mike_C's Avatar
aircraft paint stripper is the strongest stuff i know of that is easily available. sanding might be your best bet if that didn't work.
Old Mar 27, 2005 | 05:24 PM
Hump-Free's Avatar
What kind of paint is on it? Spray can, clear coat, base only, or what?
Old Mar 27, 2005 | 07:19 PM
syvikraicer's Avatar
try using the paste version of aircraft stripper and not the spray on.....i did my rotas long time ago and it ate it away easy
Old Mar 28, 2005 | 04:56 AM
Mike_C's Avatar
Default Re: (syvikraicer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syvikraicer &raquo;</TD></TR><TR><TD CLASS="quote">try using the paste version of aircraft stripper and not the spray on.....</TD></TR></TABLE>
yeah yeah that is what i assumed he used. if not, get the paste stuff!
Old Mar 28, 2005 | 05:22 AM
fillup's Avatar
thanks. i kept trying with the spray on, and its slowly working (with multiple applications though)
another question, would it be safe for me to just sand , primer, sand, then paint over the existing paint?
Old Mar 28, 2005 | 06:14 AM
Mike_C's Avatar
well if you sanded the existing paint wouldn't be there anymore.
Old Mar 28, 2005 | 08:56 AM
sittin on GOLD's Avatar
Default Re: Stripping Paint off Wheels. (fillup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fillup &raquo;</TD></TR><TR><TD CLASS="quote">Whats the easiest wasy to strip paint off of wheels? The aircraft paint stripper isnt cutting it. (spray on) The wheels were sprayed with automotive paint and clear btw, not rattle can spray paint. thanks.</TD></TR></TABLE>
i use dad's paint remover purchased @ kmart. very very strong stuffi use it on valve covers, on wheels, anything and eveyrthing. i highly recomed a good supply of latex gloves and a bucket of water. it'll burn through the latex gloves after a few seconds and u don't want that **** on ur hands.
Old Mar 28, 2005 | 04:50 PM
fillup's Avatar
Default Re: (Mike C)
i meant just enough so the primer can stick. not sanding it all the way to the metal.
m1northreat
Honda S2000
17
Apr 8, 2008 01:58 PM
jdmekrobot
Aug 5, 2007 09:24 AM
cjames235
Nov 21, 2004 04:20 PM
YipMan_Style
Jun 11, 2003 06:54 PM
NoNOSgsr!
Dec 5, 2002 09:32 PM
