all motor b18a questions
Hey guys, I hope you can help, I did search for any info, but this is more my engine specific.
I have the b18a and wish to do all-motor, it will be a daily driver dont want anything too crazy, here is what I have, please list what you belive I should get as well, and also please specify what to do for ecu
b18a will be cleaned and honed befor install
JG race series port and polished head
jg 301 cams lift in/ex is 417/408 dur. in/ex is 274/260
Holley throttle body
skunk 2 intake mani
JG cam gears
PR3 pistons stock size
what i need is the
head internals
ecu
do I need new rods
please just put down evrything you think would amke my setup complete and solid
Thanks guys
Sean
skunk 2 intake mani
JG cam gears
what i need is the
head internals
ecu
do I need new rods
Thanks guys
Sean
have your pr4 rods shotpeened. and use arp rod bolts. as well as arp head studs .use like 81.25mm or 81.5mm p30s pistons. the jg 301s are very nice cams and can be used with stock valvetrain and be taken to stock rev limit daily and be reliable .use a stock ecu tune it with uberdata to keep costs down .use a b16 or gsr tranny and lightweight flywheel and maybe an exedy stage 1 clutch.
what is the size of the holley tb?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 »</TD></TR><TR><TD CLASS="quote">have your pr4 rods shotpeened. and use arp rod bolts. as well as arp head studs .use like 81.25mm or 81.5mm p30s pistons. the jg 301s are very nice cams and can be used with stock valvetrain and be taken to stock rev limit daily and be reliable .use a stock ecu tune it with uberdata to keep costs down .use a b16 or gsr tranny and lightweight flywheel and maybe an exedy stage 1 clutch.
what is the size of the holley tb? </TD></TR></TABLE>
^ Good stuff! I agree.
sweet, thanks alot guys, and the TB is 62mm, so you guys think oversized is the way to go for pistons, seeing as I have stock bore size I was just gonna throw them in, and if I did want to go above stock rev, I should get different valves and springs and retainers?
thanks again guys, you are all a real great help
go with oversize pistons yes that way you have fresh cylinder wall and your sure its perfectly round and that throttle body is the perfect size
instead of a skunk manifold you might want to look into aebs wich to my experiance is about as good and way cheaper
you also might want to pick up a js racing style intake from http://www.passwordjdm.com i have one and it works amazing a little loud along with a aebs intake manifold and ported head though lol
good luck with your build it is almost exactly the same as my first build
hey LG R32, thanks alot man, you are a great help, I really appreciate it. I will look into all those things you suggested, thanks again, and by any chance, would you know if stock fuel parts are good or should I invest in new pump and injectors and fuel rail, and if so what should I get? and LG, what did your first build put out, or was in never dynoed?
Modified by 92_red_teg at 8:28 PM 3/27/2005
h23 injectors are good to have to preven you form running lean and they are cheap and 285cc while yours is 240cc i also used a b&m fuel pressure regulator
my first build made 152 whp with almost the same as your setup but you have a little more than i did i think
for any more questions come to http://www.nonvtec.com there are alot of guys that can help ou there
cartune network
127
Sep 17, 2007 08:03 PM
