ignition question
Old Mar 26, 2005 | 07:13 PM
coryblsmn's Avatar
Default ignition question
my civic was broken into and stolen when i was in basic traning and they stole my head unit that didnt even work .. but anyway .. in the process they ripped out my alarm system and in the process of them doing that some how now my car wont even start .. it wont turn over at all .. i turn the key and it just clicks .. i mean the batt. is fine everything else works .. it just wont start .. or attempt to start.. any suggestions on what they did .. or how to fix it .. or should i jus take it to a honda dealer( which im trying to avoid cause they will charge me an arm and a leg ) .. so can anybody help
Old Mar 26, 2005 | 08:02 PM
Ls_V_TurboSi's Avatar
Default Re: ignition question (20720racer)
check your ignition wires... Usually it gets spliced into for ignition kill which is exactly what its doing.. Either figure out whats wrong with the alarm and hook it all back up so it funtions or see which wire they spliced and hook it back up so its one peice... Try this.. turn your key on and try and push start your car.. if it starts then its what I listed above
Old Mar 26, 2005 | 11:28 PM
coryblsmn's Avatar
Default Re: ignition question (Ls_V_TurboSi)
so if it starts when i push started then they spliced my wires? .. hey could it also be jus the alternator?
Old Mar 27, 2005 | 12:11 AM
turn your key on to "on" position (so you have dash lights and stuff) Push start the car.. if it starts that means you have an igition kill.. Go do that come back and let me know if it starts.. i'll direct you from there
Old Mar 27, 2005 | 06:33 AM
BatuKing's Avatar
when you say CLICK is it comming from the starter by chance?
B16B Four Door
Sep 14, 2015 12:51 AM
djslim23
Audio / Security / Video
Dec 29, 2013 10:47 PM
kaychi
Sep 29, 2007 05:40 PM
Boostage
Oct 9, 2004 06:17 PM
JOMO
Jun 17, 2003 09:31 PM
