Does the speedo need power to move the gauge?
if no one answers ill drive my car down the block tomorrow and shut it off, and ill report my findings to you. Otherwise im a bit curious.
In all the other cars i drove the speedo stayed up when i shut it off. (at least the older ones)
Needs to be About 20% Cooler
NO THE SPEEDO DOSENT NEED POWER TO WORK. BUT IF U SHUT THE CAR OFF, THE TEMP AND TACH WILL SHUT OFF TOO.
EDIT: sorry for the caps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">NO THE SPEEDO DOSENT NEED POWER TO WORK. BUT IF U SHUT THE CAR OFF, THE TEMP AND TACH WILL SHUT OFF TOO.
Tested and true.
</TD></TR></TABLE>Tested and true.
mr6sr
Nov 30, 2004 03:31 AM
are you sure tho? Before I go into a cutting frenzy...
