MY 92 ACCORD HAS A WINDOW MOTOR PROBLEM..
Old Mar 26, 2005 | 06:52 PM
manwezy951's Avatar
Default MY 92 ACCORD HAS A WINDOW MOTOR PROBLEM..
EVERYONE I KNOW WHO HAS A ACCORD HAS THE SAME PROBLEM WITH THE WINDOW NOT WORKING>? WHY IS THAT?
Old Mar 26, 2005 | 06:53 PM
pineapplegti's Avatar
Default Re: MY 92 ACCORD HAS A WINDOW MOTOR PROBLEM.. (manwezy951)
ttt
Old Mar 26, 2005 | 07:11 PM
-RedneckDave-'s Avatar
Working
OK for one stop typing in all caps because it is annoying, and on your question. Does your window not work at all or does it just go really slowly?
Old Mar 27, 2005 | 04:37 PM
typhoon's Avatar
Default Re: MY 92 ACCORD HAS A WINDOW MOTOR PROBLEM.. (-RedneckDave-)
My old 3rd gen had a really slow passenger window. My 4th gen has no issues yet. What's the common prob you mention?
Old Mar 27, 2005 | 06:26 PM
maivietla's Avatar
Default Re: MY 92 ACCORD HAS A WINDOW MOTOR PROBLEM.. (typhoon)
If ur window doesn't work at all then u should check the fused, the swiched( up and down), If it goes up and down slowly then it's your umm.. window motor or maybe u need some greast to make it move more smooth. it hapened to me once.
Old Mar 28, 2005 | 11:41 PM
CB7VTEC's Avatar
He has to be referring to the shrinking run channel problem where it bunches up a the corner by the mirror. Pull it off the car, clean with silicone spray & stretch the crap out of it or buy a new one.
Old Apr 2, 2005 | 05:42 AM
goodOLdayz's Avatar
is that really the problem with it ? i always thought the motor was dying .
Old Apr 2, 2005 | 01:19 PM
TOP END MS's Avatar
Every accord I owned had the same problem. Im pretty sure its the motor b/c it seems to only happen on the most used window (ei Drivers side) .. But I do beleive the silicone spray will also help so, but I dont think thats the REAL problem.
Old Apr 2, 2005 | 08:26 PM
CB7VTEC's Avatar
Default Re: (goodOLdayz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goodOLdayz &raquo;</TD></TR><TR><TD CLASS="quote">is that really the problem with it ? i always thought the motor was dying .</TD></TR></TABLE>
electric motors die out slowly from the first day they're used, and though it is common for accords to have weak window motors with age, i have still seen more instances where the run channel shrinks and it kills the motor, or is at least the main cause for slow operation in combo with a dying motor.
Old Apr 2, 2005 | 09:14 PM
manwezy951's Avatar
my driver window doesnt work......passenger and back rear windows are really slow!!(reallY SLOW)
masti
53
Oct 23, 2016 11:42 AM
corkss
Nov 30, 2008 06:46 PM
chickpat
Jan 21, 2008 05:40 PM
Lostmind004
Nov 22, 2005 12:58 PM
