CP 12.5 Pistons but which one???
I was planning on running OEM B16 pistons in order to raise my compression on my LSVtec but ive decided to go higher 12.5 and have been looking on CP's website but they have two types i guess regular and x style forged. Im just tryin to figure out which one would be best for my set-up. Any suggestions???
http://www.cppistons.com/sCompactNEW.htm
USDM ITR tranny
Centerforce Stage 3 Clutch
Toda Flywheel
GSR Head:
Rocket MortorSports Springs & Retainers
Rev Valves
3 angle valve job
port matched intake mani
Skunk2 intake mainfold
Skunk2 Camgears
APR Head Studs
Cometic Head Gasket
DC 4-1 Headers
ITR Throttle Body
Buddy Club IV Cams
P28 Chipped
LS Block:
OEM B16 Pistons w/ rings
Golden Eagle Block Guard
Golden Eagle Girdle Kit
ARP Rod Bolts
Golden Eagle LSVtec Kit
USDM ITR tranny
Toda Flywheel
GSR Head:
Rev Valves
3 angle valve job
Skunk2 Camgears
APR Head Studs
Cometic Head Gasket
DC 4-1 Headers
ITR Throttle Body
Buddy Club IV Cams
P28 Chipped
LS Block:
ARP Rod Bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">The x style piston is designed for na.The other series is designed for fi or nos.
Glenn</TD></TR></TABLE>
thanx for the post
thanx for the post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-6 hatch »</TD></TR><TR><TD CLASS="quote">just get some pct pistons from honda ( ctr's) or you could just mill the head man </TD></TR></TABLE>
i believe there was some conflict between CTR pistons and a GSR head as far as clearance
had pct in my gsr motor for 25000 miles, runs good w/ octane, but when i took off the head, there was the arrow and IN mark imprinted to the head from the pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaIntegraR »</TD></TR><TR><TD CLASS="quote">had pct in my gsr motor for 25000 miles, runs good w/ octane, but when i took off the head, there was the arrow and IN mark imprinted to the head from the pistons</TD></TR></TABLE>
so there is some clearance issues.. is there much difference in compression between the B16's and 12.5 x style
votoms888
May 14, 2007 08:03 PM
boostd ls
Feb 5, 2006 01:10 PM
