help plz
Old Mar 26, 2005 | 03:39 PM
91civichatchCrX's Avatar
Default help plz
is the conversion from dpfi to mpfi the same as the conversion from a b20 goin into a dx?
Old Mar 26, 2005 | 03:41 PM
RCautoworks's Avatar
Default Re: help plz (91civichatchCrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civichatchCrX &raquo;</TD></TR><TR><TD CLASS="quote">is the conversion from dpfi to mpfi the same as the conversion from a b20 goin into a dx? </TD></TR></TABLE>
b20 only tells us your using a b20 block. What head are you using, it should be pretty much the same, depending on what head your using ( obd0, obd1, or obd2 )
mr. carpenter's Avatar
no. search mpfi swap archived or better yet there is a thread at the top of this forum called faq that has some good mpfi write ups and links.
Old Mar 26, 2005 | 03:44 PM
it has a b16A head, and its obdo
Old Mar 26, 2005 | 03:46 PM
Default Re: (91civichatchCrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civichatchCrX &raquo;</TD></TR><TR><TD CLASS="quote">it has a b16A head, and its obdo</TD></TR></TABLE>
Yep then its the same, well depending on what ecu your using.
Old Mar 26, 2005 | 03:50 PM
pw0 ecu
Old Mar 26, 2005 | 04:10 PM
Yep should be the same thing
Coolero
Oct 15, 2007 05:43 AM
92hatchGSR
Sep 28, 2005 07:17 PM
PFSeg
Nov 24, 2004 08:58 AM
MysticSpade
Dec 31, 2003 09:12 PM
