Suspension & Brakes Theory, alignment, spring rates....
glazed brakes?
Old Mar 26, 2005 | 12:35 PM
kaj's Avatar
kaj
Default glazed brakes?
after a very spirited mountain session, my brakes squeek. they were fine before and noticed a bit of noise after the run and having let them cool down. it got pretty bad... then we had a week of rain, now it's not so LOUD, but still there.
anything i can do? there's plenty of pad left all the way around ..
is it the pad surface or do i just need to add more anti-squeek junk? i know the brakes got pretty hot on that moutain run. can that break down the anti-squeek, assuming there was some?
Old Mar 26, 2005 | 01:11 PM
jeremyG2teg's Avatar
Default Re: glazed brakes? (kaj)
What kind of pads are you using and how long have you been using them???
Old Mar 26, 2005 | 03:37 PM
kaj's Avatar
kaj
Default Re: glazed brakes? (jeremyG2teg)
to be honest, i have no clue. i'm gonna assume they are not the OEM pads.. nobody ever replaces brake pads with OEM. they aren't colored like some after-market pads.. they LOOK normal. i bought the car used, so i have no clue what the guy put on.
would it make a difference as to why the were fine before the mountain run and squeeking after?
Old Mar 26, 2005 | 06:09 PM
yudalicious's Avatar
probably a good indication to change pads, safety is always first.
Old Mar 26, 2005 | 06:39 PM
TheCowGod's Avatar
I did the same thing when I got my Del Sol, my brakes sqeeked off and on for about a year before the pads wore down and it was time to change them.
I never had any problem stopping though. Also the pads were what was on the car when I bought it. They were absolutly horrible, literealy I would get brake fade slowing down while getting off the freeway.
Old Mar 27, 2005 | 12:08 PM
kaj's Avatar
kaj
Default Re: (TheCowGod)
wow. mine aren't that bad. they stop just fine.. just squeek. i also have about 3/16-1/4" of pad left all the way around.. i'm just thinking that the heat from my drive may have damaged the material. eh. i bought cobalt/axxis pads, i'll just throw them on and save these as back up for an emergency..
Old Mar 27, 2005 | 07:26 PM
vdub08's Avatar
mine do the same, i was gunna change em like last week, but i went on vacation so i didnt get a chance to do it
Old Mar 27, 2005 | 08:20 PM
STperformance's Avatar
have a shop re-surface the rotors and scuff the pads slightly with sand paper. Or if your going to install some different pads still have someone re-surface the rotors. You've probaly caused hot spots on your rotors and over heated the pads, basically if you could imagine glass on glass.
Old Mar 28, 2005 | 11:04 AM
kaj's Avatar
kaj
Default Re: glazed brakes? (STperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STperformance &raquo;</TD></TR><TR><TD CLASS="quote"> You've probaly caused hot spots on your rotors and over heated the pads, basically if you could imagine glass on glass.</TD></TR></TABLE>
pretty much as i suspected
dc2LS
Jul 29, 2010 09:14 AM
civic710
Honda Civic (2006 - 2015)
12
Mar 19, 2009 08:08 PM
Mr. Projekt
Honda S2000
10
Jan 18, 2005 12:27 PM
OEMaccord
13
Sep 20, 2002 11:08 AM
WuShu
May 18, 2001 12:43 PM
