HELP
Old Mar 26, 2005 | 10:55 AM
JDM RHD eg6's Avatar
Default HELP
hey guys i have a jdm d15b vtec motor, im not running vtec yet but going to soon , i need to know what kind of dizzy would work for my d15b motor? right now im using a d16a6 dizzy,but the timing is a little off and running rich right now black smoke and alot of my gas is gone...reply thanks
Old Mar 26, 2005 | 11:06 AM
mr. carpenter's Avatar
Default Re: HELP (MrEF8)
does the a6 dist. fit properly? i think the dist. from a 92 vx would work? it's motor is basically the equivalent u.s. motor to the d15b
Old Mar 26, 2005 | 11:10 AM
Default Re: HELP (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">does the a6 dist. fit properly? i think the dist. from a 92 vx would work? it's motor is basically the equivalent u.s. motor to the d15b</TD></TR></TABLE>
no the a6 dont work properly and if the timing is off and running rich, does gas and black smoke comes out to be that problem, because of the a6 dizzy? Gas mileage sucks
Old Mar 26, 2005 | 11:25 AM
are you using the a6 intake manifold or the 15b? your dist. and injectors need to match your ecu. that is an obd1 motor that's supposed to run off of a p28 ecu or a hondata or zdyne. get your timing correct fist. that dist. will work on that motor. i'm running an a6 dist. on a z6... well i was till it blew up yesterday, anyway i had to modify the legs with a dremel in order to get the dist. to mount and have timing adjustability. i'll go take some pics and get them up so you can see how i did it.
Old Mar 26, 2005 | 11:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">are you using the a6 intake manifold or the 15b? your dist. and injectors need to match your ecu. that is an obd1 motor that's supposed to run off of a p28 ecu or a hondata or zdyne. get your timing correct fist. that dist. will work on that motor. i'm running an a6 dist. on a z6... well i was till it blew up yesterday, anyway i had to modify the legs with a dremel in order to get the dist. to mount and have timing adjustability. i'll go take some pics and get them up so you can see how i did it.</TD></TR></TABLE>
I'm using the a6 intake manifold with the a6 injectors, and yes my stock ecu and dizzy. Car running very rich and gas sucks and is theres any problems i should check for? can it be the timing?
sorry about your motor what happen to it?
Old Mar 26, 2005 | 11:42 AM
get that timing straightened out first. i've got a link to a thread that shows how i did it. it's highly ghetto but it works.
as for my motor we were at the track yesterday and after about 6 laps i noticed the temp. climbing so i pull in and see my coolant resivoir is open and i'm losing water. i let it cool down and put water back in. go back out and begin to hear a slight chatter. by the time i got back to the paddock it was clanking a little worse. called it a day and tried to limp it home. i made it about 10 miles before it began to lose compression and was banging like bad so i pulled it over and called my buddy and the pregnant wife and i sat under a tree for 3 1/2 hours while he sourced a tow dolly. cars home now and i never threw the rod but i think in all the heat the oil thinned out and i spun a bearing. at least that's what it sounds like. hav'nt got into it yet. i gotta get a new one though. it was a z6 that i only paid 50$ for and i got 6 track events and about 2 years of daily driving from it so i'm sad to see it go but it served me well. i'll try to find that thread for you.
Old Mar 26, 2005 | 11:45 AM
here it is.
https://honda-tech.com/zerothread?id=913151
Old Mar 26, 2005 | 11:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">here it is.
https://honda-tech.com/zerothread?id=913151</TD></TR></TABLE>
thank you for looking for the link and helping me out, but the zc an the d15b is a little diff right? well as the a6 dizzy?
Old Mar 26, 2005 | 11:53 AM
z6 not zc. it's basically the same head with a 1.6 block.
Old Mar 26, 2005 | 11:56 AM
yea the z6 sorry
the link that you give to look at the pic and the one that i have the right timing is way off the line.
thats how mine looks like right there in blue
Modified by MrEF8 at 1:07 PM 3/26/2005
Old Mar 26, 2005 | 12:10 PM
if you just woller out that top hole some the bolt will go in without having to cut that chunk out. if you look at the 2nd set of pics in that thread, that's mine. the other guys work is alot cleaner. but yeah your timing is way off.
Old Mar 26, 2005 | 12:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">if you just woller out that top hole some the bolt will go in without having to cut that chunk out. if you look at the 2nd set of pics in that thread, that's mine. the other guys work is alot cleaner. but yeah your timing is way off. </TD></TR></TABLE>
so what should i do bro? if im running rich is it the timing?
as long as the dizzy holds on the right timing then its all good? no more running alot of gas miles?
Old Mar 26, 2005 | 12:31 PM
i would start there. take all the bolts out and just hold the dist. with your hand. get some one to start the car then adjust it. ideally you need a timing light but you can get it close enough by ear. at least better than what you have now. do you have a dremel or something you can widen that hole with. if so then you can at least get that top bolt in.
Old Mar 26, 2005 | 12:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">i would start there. take all the bolts out and just hold the dist. with your hand. get some one to start the car then adjust it. ideally you need a timing light but you can get it close enough by ear. at least better than what you have now. do you have a dremel or something you can widen that hole with. if so then you can at least get that top bolt in.</TD></TR></TABLE>
whats a timing light? and need more info about that thanks...
Old Mar 26, 2005 | 12:45 PM
you use it to verify that the #1 plug is firing when just before the #1 cylinder hits tdc. it's a light that flashes and you point it at the crank pulley sight on the timing cover. when it lights you should be able to see the timing marks on your crank pulley line up in the sight. one mark alone is tdc and there is a set of three marks that are 18 deg. +/- 2 deg. before tdc. the light should be lighting these marks. you can usually rent one at autozone.
Old Mar 26, 2005 | 12:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">you use it to verify that the #1 plug is firing when just before the #1 cylinder hits tdc. it's a light that flashes and you point it at the crank pulley sight on the timing cover. when it lights you should be able to see the timing marks on your crank pulley line up in the sight. one mark alone is tdc and there is a set of three marks that are 18 deg. +/- 2 deg. before tdc. the light should be lighting these marks. you can usually rent one at autozone.</TD></TR></TABLE>
so i can use that to put the timing on right?
Old Mar 26, 2005 | 12:54 PM
correct.
Old Mar 26, 2005 | 12:57 PM
well ill go and see if any of the auto shops have one to rent
how many mpg you running? im running like 16 mpg with no vtec running...LOL
Old Mar 26, 2005 | 12:59 PM
was running about 25-30 mpg
Old Mar 26, 2005 | 01:03 PM
holy **** i just saw your sig. do you ship those motors or local only? if you ship, do you still have a d15b available? that's really going to be the simplest for me because i don't have time to wait for a z6 and the d15b will drop right in no wiring for me . i'm just shopping right now.
Old Mar 26, 2005 | 01:04 PM
do i have to rent a timing light? or can i just try to put the timing on the right spot and see where my rpm goes to?
Old Mar 26, 2005 | 01:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">holy **** i just saw your sig. do you ship those motors or local only? if you ship, do you still have a d15b available? that's really going to be the simplest for me because i don't have time to wait for a z6 and the d15b will drop right in no wiring for me . i'm just shopping right now.</TD></TR></TABLE>
yes sir i still have them
Old Mar 26, 2005 | 01:06 PM
that's what i was saying is you can get it pretty close by ear. the timing light will get it dead on. how long has your car been running like this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">that's what i was saying is you can get it pretty close by ear. the timing light will get it dead on. how long has your car been running like this?</TD></TR></TABLE>
1 week, dont wanna drive my car because of the gas, its running like 13 or 16 mpg...
Old Mar 26, 2005 | 01:12 PM
yeah i would'nt drive it too much like that. the unburned fuel will go into the cat and burn there and melt the catalyst. like i said you don't need the light. especially since yours is way off. get that top leg to line up and get it bolted down. it should improve somewhat. i'll keep in touch with you about the motor. i'm going to look locally first. do you have any idea what shipping would be to houston 77373?
