Really annoying problem!!! can some1 plz help me????
Old Mar 26, 2005 | 10:12 AM
Econo'Box's Avatar
Default Really annoying problem!!! can some1 plz help me????
My horn will NOT work at all I have checked all connections all the grounds are good and all positive leads before the steering wheel are good. I already put in a new cable reel and I have cleaned the connections inside the steering wheel. The horn works it was tested by hooking it straight tto the battery. Any help to fix this would be greatly appreciated.
Old Mar 26, 2005 | 10:23 AM
Econo'Box's Avatar
Default Re: Really annoying problem!!! can some1 plz help me???? (tabrisakakaoru)
BUMP... come on ppl I need to get this fixed
Old Mar 26, 2005 | 02:12 PM
boostedegcpe's Avatar
When you say all the grounds are connected . . . kind of threw me off.
i could be wrong but I think the horn is a negative trigger. Meaning when you push the horn a close the loop . . . it actually grounds the loop, instead of giving it the 12v you think its suppose to do. make sure when you "grounded everything, you didn't short a wire. check fuses and such.
scottmog
Jul 1, 2009 05:55 PM
zman
Oct 29, 2008 09:06 AM
tyco
Nov 11, 2007 09:19 PM
