Dynamat
I have 200 dollars, my car is stripped down to the metal right this very second, and i want to put in sound deadening to reduce road noise.
I stripped it yesterday and the **** i bought didn't work. What should i buy and where should i buy it?
how much of the car are you going to dynamat? if just parts you can go to you local best buy or stereo shop and pick up a couple of the dynamat extreme 2 door kits that are 12 sq ft per pack they are about 90 dollars i think, or if your going to do the entire car you might look soundomain.com and buy it in bulk you can also look for dynamat, dynamat extreme, brown bread, acu mat, there are a ton of different possiblitys for the car you can also look into using a spray on like rhino liner or the stinger product that is foam and it expands in hard to reach places
Dynamat is incredibly overpriced. Its not going to kill all noise, will help to kill some low frequency road noise. Your best bet is foam carpet padding, add another layer or 2 to whats there if you really wanna kill some noise.
Dont forget to do outer door skins and your firewall! Or your roof!
i'm changing to ecutout + stock exhaust to combat the new motor mounts increaced exhaust noise. I guess i'll just drive around for awhile with nothing inside the car till i get that fatmat, i just ordered it.
Do i have to take off the dash to get to the firewall, how long does that take? You think i should remove the upholstry on the roof and do that as well?
if i have 100sq ft i think i have pleanty to do it all.
Cherry Blossom
Apr 6, 2005 11:28 AM
2000Accord5sp
Audio / Security / Video
Oct 21, 2002 01:16 PM
