Need a "how to" to change fuel injector
Old Mar 25, 2005 | 09:49 PM
Mike1486's Avatar
Default Need a "how to" to change fuel injector
One of my fuel injectors died.... I need a how to guide/instructions to remove the old one and replace it with a new one. I have a '93 integra GS 1.8 ltr I4 DOHC automatic tranny. Thanks in advacne
Old Mar 25, 2005 | 10:09 PM
Evanmb44's Avatar
Default Re: Need a "how to" to change fuel injector (Mike1486)
unplug injector clip.
make sure you relieve fuel pressure, take the gascap off.
remove the fuel rail
pop out the injector
install new injector
reverse the above
it doesnt take very long and is quite simple to do
Old Mar 25, 2005 | 10:25 PM
SuzukaBlueAP2's Avatar
Default Re: Need a "how to" to change fuel injector (Evanmb44)
That's it in a nutshell. If you can't figure that out, you probably shouldn't be working on your car. And if you need extra visual help, I suggest purchasing a service manual.
Old Mar 26, 2005 | 02:21 AM
SoEvoL's Avatar
Default Re: Need a "how to" to change fuel injector (ScreaminTeg)
its pretty much self explanatory, had to do my injectors 3 times, so i got really good at it. just make sure when u are switching injectors that u get the same sized injectors and u dont tear the o rings on it.
Old Mar 27, 2005 | 01:12 PM
SSBPGSR's Avatar
Default Re: Need a "how to" to change fuel injector (JDMCrx89)
if u really need it, ill go take some pics and do a write up for you. its really easy and simple, not time consuming at all.
blu3fan
Nov 16, 2012 05:05 PM
svacca1
Sep 7, 2007 09:41 AM
e jay one
Mar 26, 2007 03:58 PM
maximedx
Feb 5, 2002 04:36 AM
