in the middle of a MPFI swap. How do I depin the ecu?
Old Mar 25, 2005 | 08:01 PM
teknohatchie91's Avatar
Default in the middle of a MPFI swap. How do I depin the ecu?
yeah it might sound stupid but what kind of tool do I need to depin the ecu plugs?
thanks
Old Mar 25, 2005 | 08:09 PM
civickiller's Avatar
Default Re: in the middle of a MPFI swap. How do I depin the ecu? (teknohatchie91)
i used little flat head glasses screwdriver
Old Mar 25, 2005 | 08:28 PM
NikoZai's Avatar
Default Re: in the middle of a MPFI swap. How do I depin the ecu? (civickiller)
thats the one - see http://www.rywire.com/dpmpfi.shtml
At the bottom it says "You will need this tool to extract the pins from the ecu plugs"
Old Mar 25, 2005 | 08:30 PM
coot_er's Avatar
Default Re: in the middle of a MPFI swap. How do I depin the ecu? (NikoZai)
some people just use a paper clip. i used a small pointed tool, i think its called an aw?
Old Mar 25, 2005 | 08:33 PM
Default Re: in the middle of a MPFI swap. How do I depin the ecu? (coot_er)
I see, should I "attack" the pin from the bottom or top? Is there a special way to do it or no? I just dont wanna **** it up.. thanks
Old Mar 25, 2005 | 08:54 PM
gutterslide's Avatar
i use a tiny screwdriver like shown on the rywire page.
here are some detailed instructions. it's a google cache, unfortunately the original site is down, so no pics.
http://64.233.161.104/search?q...fox-a
first fourthgenhatch.com, now deepstaged.net.
Old Mar 25, 2005 | 09:02 PM
Default Re: in the middle of a MPFI swap. How do I depin the ecu? (gutterslide)
all right, just what I needed. thanks a lot
Old Mar 25, 2005 | 09:17 PM
the tool
insert here
this is what you'll be doing with the tool, inside the plug
tab on the pin
the tab clips onto a bar that runs the length of the plug that holds pin in place.
insert the tool so it goes on either side of the bar
the A plug works much the same way, but is easier.
Modified by gutterslide at 6:41 AM 3/26/2005
Old Mar 26, 2005 | 08:47 AM
Default Re: (gutterslide)
wow, thanks again. That really helps. Now I just need to find me a tool like that lol...
l8er
Old Mar 26, 2005 | 08:55 AM
ShitBoxCrx's Avatar
paper clip works fine I hold the wire with my teeth and run the paper clip in and out where the tab and sooner or later it comes out. Paper clips like to deflect though so you have to keep turning around against it's bends. Keep only very slight pressure on the wire and if you can only when you know the tab is down obviously the pressure you put on it will keep the tab in place. Werd tell us how it goes.
Old Mar 26, 2005 | 11:49 AM
boosted_hatch_216's Avatar
Default Re: (ShitBoxCrx)
i just used a eyeglass screwdriver worked great and wow whos finger is that in your avatar shitbox looked like it hurt.
StorminMatt
Feb 27, 2008 04:33 PM
mellowhead
Honda S2000
Aug 3, 2006 10:30 AM
wildcard69
Apr 11, 2005 06:49 PM
kagegod
Jun 30, 2004 01:22 AM
shorty91
Jun 25, 2003 09:48 AM
