Auto Start Pulse Problems????
i have a clifford rsx 3.5 alarm just installed everything was working fine then i unplugged the battery to put a new one in and my auto start pulse is really short. i no you have to do something with the valet switch but i dont no what. and it results to a longer pulse for the starter. if any one has any info pls let me know thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceMyHatchBack »</TD></TR><TR><TD CLASS="quote">i have a clifford rsx 3.5 alarm just installed everything was working fine then i unplugged the battery to put a new one in and my auto start pulse is really short. i no you have to do something with the valet switch but i dont no what. and it results to a longer pulse for the starter. if any one has any info pls let me know thanks </TD></TR></TABLE>Not sure what you mean by "pulse", doorlock pulse? crank time? what is not happening? or what is not happening? if you mean crank time, it should not have changed when you replaced the batt., but you may have latched up the Clifford brain, try disconnecting the neg. batt term. wait a min. then reconnect, try the remote start.
94
94
yea its the crank time for the starter it dosent crank enough for the engine to start i thought it had to do something with the valet switch so it would crank longer?
As FCM stated, the Clifford should retain the programming after losing power.
If for some strange reason you do need to reprogram it, it is done with the valet switch.
To change crank time:
1. Open door
2. Turn ignition on and then back off
3. Press and hold the valet switch until the led flashes 3 times. Horn/siren should also chirp 3 times with the led.
4. Press the valet switch 5 times, and then press and hold the switch. LED should flash 5 times to confirm.
5. With the valet button held, pressing the unlock button on the remote will change the crank time between 0.8,1.0, 1.2,1.4, 1.6, 1.8, 2.0, and 4.0 seconds. Pressing the lock button will set crank time to 0.6 seconds.
I recommend pressing the lock button to get yourself back to 0.6 seconds, and then pressing the unlock button to start advancing through the crank times.
Good Luck!
1. Open door
Good Luck!
