axles for b16a swap into 91 civic dx
Old Mar 25, 2005 | 05:20 PM
wood's Avatar
Default axles for b16a swap into 91 civic dx
I have a 91 civic dx that I put a JDM b16a with j1 transmission in. Itis from a 90 Integra which I purchased as a front clip. Will the axles work and what other components from the Integra do I need to use?
Modified by wood at 6:58 PM 3/25/2005
Old Mar 25, 2005 | 05:23 PM
Magick211's Avatar
Default Re: axles for b16a swap into 91 civic dx (wood)
the integra axles, intermediate shaft will work, you will have to modify/shorten the shiftlinkage
Old Mar 25, 2005 | 06:35 PM
wood's Avatar
I tried installing the integra axles with the stock civic damper fork in place, but it was binding up and on removal, I found that the rectangular side of the roller bearings were broken. do I need to use the shock/ damper fork from the integra, or did I install the roller bearings backwards? It was hard to get thelower control arm back on, and the axle seemed to be at an awkward angle. any info on how to install is greatly apperciated
Old Mar 25, 2005 | 08:39 PM
EP3_05's Avatar
What mounts are you using. I have had no problem using the teg axles on my b series swaps with stock civic suspension components.
Old Mar 25, 2005 | 10:32 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood &raquo;</TD></TR><TR><TD CLASS="quote">I tried installing the integra axles with the stock civic damper fork in place, but it was binding up and on removal, I found that the rectangular side of the roller bearings were broken. do I need to use the shock/ damper fork from the integra, or did I install the roller bearings backwards? It was hard to get thelower control arm back on, and the axle seemed to be at an awkward angle. any info on how to install is greatly apperciated</TD></TR></TABLE>
You need to remove the lower fork to install the axle. Also, did you remove the rings on the end of the Integra axles? If not, you need to do so, or else you will run into binding issues. You may also have to remove the rings on the hubs as well. Like it was asked previously, what mounts are you using?
Old Mar 26, 2005 | 04:10 AM
wood's Avatar
Default Re: axles for b16a swap into 91 civic dx (91civic)
the mounts are aftermarket but I don't remember what brand. one thing I didn't mention earlier- car was auto, converting to manual.
Old Mar 26, 2005 | 02:52 PM
wood's Avatar
problem solved. bought 90 integra axles and everything went togeather like a dream! thanks to all for their help
Black99dc
19
Apr 28, 2008 10:24 AM
JUN.
Mar 13, 2008 06:26 PM
xpman
Mar 1, 2006 01:49 AM
Power Rev Racing
10
Jul 1, 2005 07:08 AM
85mm LS VTEC
Feb 22, 2005 10:26 AM
