Overstock and Garage sale ACL, Probe, GE sleeved blocks, ITB's
Old Mar 25, 2005 | 01:39 PM
DonF's Avatar
Default Overstock and Garage sale ACL, Probe, GE sleeved blocks, ITB's
ACL "B" series kits Rod, Mains, Thrust bearings, LS $65.00, GSR $72.00
ACL Comp Bearing kits LS $95.00, GSR $102.00
NDC kits with PolymerDynamics coatings LS or B-16 $94.00
NDC uncoated LS or B-16 $60.00
1 set OEM type "R" pistons .25mm over/rings/pins machined for LS rods $210.00
1 set Probe pistons 81.5mm rings/pins +7.1 dome $325.00
1 set Accralite pistons 82mm rings/pins +7mm dome $475.00
1 set #7020 84.5 CP Turbo pistons rings/pins $475.00
1 set Probe steel GSR rods $275.00
1 set titanium GSR rods $1000.00
1 Type "R" LSD with bearings, Bolts, and speedo drive $550.00
1 LS block Golden Eagle Sleeves and "O" ringed 84.5 and CP turbo pistons $1450.
! GSR block, Golden Eagle sleeved block, used needs 86mm bore $850.00
! LS block GE sleeved, needs to be finish bored and honed $850.00
1 set 954 Honda ITB's $160.00
1 set GSXR ITB's $170.00
1 set Hyabusa ITB's $175.00
! set SK Stg. 3 cams used, dyno time only $450.00
1 set Sk Pro1 cams used dyno time only $500.00
! GSR long block used but checked $1500.00
1 GSR trans $600.00
1 H-22 cylinder head complete, less 1 rocker shaft and some bolts $400.00
Old Mar 25, 2005 | 02:34 PM
DonF's Avatar
Default Re: Overstock and Garage sale ACL, Probe, GE sleeved blocks, ITB's (DonF)
BUMP
Old Mar 26, 2005 | 07:59 AM
DonF's Avatar
Up for the weekend.
Old Mar 26, 2005 | 04:07 PM
pr0honda's Avatar
bump for don
Old Mar 29, 2005 | 06:46 PM
pr0honda's Avatar
Default Re: Overstock and Garage sale ACL, Probe, GE sleeved blocks, ITB's (pr0honda)
bumpitybump
Uniquerootz
13
Jun 21, 2007 02:45 PM
RHDcivicSIR
Jan 11, 2007 06:33 AM
truteg801
Oct 27, 2005 05:15 AM
jeremy.
23
Apr 27, 2005 02:20 PM
