will a 7 inch tire fit on a 5 inch wide rim?
Old Mar 25, 2005 | 01:36 PM
honda06si's Avatar
Default will a 7 inch tire fit on a 5 inch wide rim?
Old Mar 25, 2005 | 02:17 PM
Mike_C's Avatar
what is a 7 inch tire? what is on the sidewall? 7 inches = 177mm. yes, a 177mm tire will fit on a 5" wheel, but i really don't understand what you mean or where you got that number from.
Modified by Mike C at 6:48 PM 3/25/2005
Old Mar 25, 2005 | 02:39 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: will a 7 inch tire fit on a 5 inch wide rim? (honda90si)
Werd. Tire sizes are specified with treadwidth, aspect ratio, and wheel diameter - for example, 205/50-15.
Whatever make, model, and size (e.g. 205/50-15) of tire you're considering, look up the specs for that make/model/size. You can find them on the website of tire dealers (e.g. Tire Rack) or the tire's manufacturer. It will show an "approved rim width" and you can use that to determine whether the tire will fit. If it says that the approved rim widths for a given tire are 5.0-7.0 inches, then you can use it on a 5 inch rim as well as a 7 inch rim.
Old Mar 25, 2005 | 06:59 PM
honda06si's Avatar
Default Re: will a 7 inch tire fit on a 5 inch wide rim? (nsxtasy)
thanks. i was talking about drag slicks. they are 7 inches wide and i know my steelie is 5 inches wide
Old Mar 25, 2005 | 09:11 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote">thanks. i was talking about drag slicks. they are 7 inches wide and i know my steelie is 5 inches wide</TD></TR></TABLE>
What's the brand and model, and what's the size on the sidewall?
Old Mar 26, 2005 | 07:13 AM
Mike_C's Avatar
i don't know anything about drag slicks so i'm out of this one
BUT if that is the treadwidth it = 177mm and will fit
BillyRay
May 17, 2011 01:05 PM
2wheelhunter
Jul 22, 2008 01:06 PM
SJR
Dec 3, 2004 08:25 AM
inline4
Jul 25, 2004 03:49 PM
garados
Jul 28, 2002 03:17 PM
