F*ckin Crank wont come off oil pump
Old Mar 25, 2005 | 11:50 AM
JDMlyfestyle's Avatar
Default F*ckin Crank wont come off oil pump
Just taking my crank out of my B16 and it wont come off the damn Oil pump. its like seized in there. how the hell do i get the damn thing out. I tried PB and WD. i dont want to use a hammer and mushroom the end of the crank.
Old Mar 27, 2005 | 02:02 PM
anyone help? the damn gear is just stuck on there and it wont come off. can anyone help me?
Old Mar 27, 2005 | 03:08 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: F*ckin Crank wont come off oil pump (JDMlyfestyle)
heat the gear, and lightly pry on each side w a screwdriver.
Old Mar 27, 2005 | 06:10 PM
i already tried that. i think i might have to find a press.
Old Mar 27, 2005 | 08:54 PM
rjay8604's Avatar
Default Re: (JDMlyfestyle)
I don't get the problem. Timing gear stuck on crank. Oil pump won't slide off? what exactly is stuck. ?
Old Mar 27, 2005 | 09:57 PM
yes the timing gear is stuck. and i need to get the oil pump off so i can send the crank in to get micropolished and have it checked out.
Old Mar 28, 2005 | 02:57 AM
AzN_Flava's Avatar
ttt, cuz I would like to figure it out too
Old Mar 28, 2005 | 11:42 AM
Just tried heating it up and 2 pry bars and it didnt budge.
Old Mar 28, 2005 | 12:55 PM
im_poor's Avatar
try a pulley puller of some sort.
Old Mar 28, 2005 | 12:57 PM
thats a good idea
Old Mar 28, 2005 | 01:03 PM
im_poor's Avatar
spray some pb buster at it as well (lubricant)
Old Jul 6, 2005 | 11:39 AM
ss20gsr's Avatar
Default Re: (im_poor)
i just did this yesterday, I think this is your problem.
If you cant get the timing gear off, get the flywheel off and put two of the flyywheel bolts back in and put a bar in between the two bolts (i used my jack bar) and this will hold the timing gear so it doesnt spin free. losen the timing gear and then take off the oil pump, u can use a flat tip to pop it off. I stopped there, but i will finish today.
hope that helps, gluck
Old Jul 6, 2005 | 05:55 PM
moto1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Just tried heating it up and 2 pry bars and it didnt budge.</TD></TR></TABLE>
what did you heat it with, sounds like it didn't heat enough or the heat didn't stay concentrated in the gear alone. I have been through a ton of these, the right heat and two lady feet and your good.
Some times a brass punch and a good hammer and nailing it all the way aroung the face will crack the oxidization or rust loose and allow your penetrant in.
relited
Apr 11, 2007 06:50 PM
relited
Apr 11, 2007 04:55 PM
slowteg550
May 18, 2006 03:53 PM
See Are X
Feb 11, 2005 09:13 AM
See Are X
Nov 12, 2003 04:14 AM
