B17 sleeveing
Old Mar 25, 2005 | 10:29 AM
iHeartIntegraDA's Avatar
Default B17 sleeveing
If I sleeve my b17 and I get ctr pistons to put in it will they still be able to fit?
Please help a noob out. Just really worried that I would be wasting money.
Old Mar 25, 2005 | 10:55 AM
Jasper_db1's Avatar
Default Re: B17 sleeveing (iHeartIntegraDA)
Why bother sleeving if you're going to use an OEM piston? Bore to 85mm and get some customs!
EDIT, I'm in CA and have PCT in my B17a. You HAVE to get it tuned to run right. 12.25+ compression is fun, but not on 91 octane.
Old Mar 25, 2005 | 10:57 AM
I just wanted to get rid of all the carb build up on the walls.
Old Mar 25, 2005 | 10:58 AM
Used2beAb16's Avatar
shouldnt be buildup on the walls
Old Mar 25, 2005 | 02:34 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHeartIntegraDA &raquo;</TD></TR><TR><TD CLASS="quote">I just wanted to get rid of all the carb build up on the walls.</TD></TR></TABLE>
Then spray them with a $4 can of carb cleaner, don't spend $1000+ on sleeves. How do you have carbon buildup on the walls?
Old Mar 25, 2005 | 04:14 PM
Kendall's Avatar
May I recommend P30's as opposed to PCT's. You'll have more valve clearance, a bit less compression, and easier/less expensive tuning when compared to the PCT's.
Old Mar 25, 2005 | 05:58 PM
rjay8604's Avatar
Default Re: (Kendall)
good advice above. Definitely no need to sleeve.
Old Mar 26, 2005 | 03:23 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHeartIntegraDA &raquo;</TD></TR><TR><TD CLASS="quote">If I sleeve my b17 and I get ctr pistons to put in it will they still be able to fit?
Please help a noob out. Just really worried that I would be wasting money.</TD></TR></TABLE>
There is no need to resleeve unless (1) you want to increase displacement, (2) you are going to run boost, and/or (3) the engine has been bored to the service limit.
lostone808
10
Mar 4, 2006 12:52 PM
PinkMaggit
Dec 17, 2005 10:09 PM
careawholelot
Aug 29, 2005 07:42 AM
Fate
Dec 12, 2004 06:18 PM
andrewasf77
12
Feb 11, 2004 01:45 PM
