F.S. Endyn knife edged and balanced Type R crankshaft.
cuts through the gases in the crankcase better and as already said, its lightweight which helps the motor rev better kinda like a lightweight flywheel.
scott
scott
I am goin out on a limb here but I think the Type R crank is balanced a little better from the factory so that it can rev. to 8400rpm. None of that matters now that I have had it Knife edged. So the answer to your question is yes you would benefit from it because it makes it safer for you to rev your motor to high rpms.
scott
scott
