car doesn't start with spare key
Old Mar 25, 2005 | 10:17 AM
pang07's Avatar
Default car doesn't start with spare key
i have accord 2000 LX where i had battery replaced and transmission computer replaced recently. today when i was starting the car with regular spare key , it doesn't start. when i use my regular key which i was using(which was used by mechanic also ) it starts. what might be the issue here
Old Mar 25, 2005 | 10:38 AM
JimBlake's Avatar
Default Re: car doesn't start with spare key (pang07)
I think in 2000 there isn't a separate tranny controller. It's all together in the 'powertrain' controller. Including the immobilizer??
So when the mechanic did that, he needed ALL the keys to enable them for the immobilizer. I believe you can't add/subtract keys without deleting the old list entirely. So maybe your valet key doesn't work anymore either.
Old Mar 26, 2005 | 11:08 AM
ILCD5's Avatar
Default Re: car doesn't start with spare key (JimBlake)
You are probly gonna have to take all your keys in to get them re-programmed to the computer. If you mechanic doesn't have the software then you are gonna have to have a dealer do it .
Old Mar 26, 2005 | 08:04 PM
zallenz's Avatar
the mechanic did it wrong, up to i believe 6 keys can be programmed for one vehicle, he must not have programmed the other ones correctly. you're probably going to have to take it to the dealer.
Old Mar 27, 2005 | 01:53 PM
RA042426's Avatar
when i comes to keys Go to dealer, it's always best.
Old Mar 28, 2005 | 11:23 PM
CB7VTEC's Avatar
If your spare key doesnt look like your original key, chances are you don't have a programmable spare key. Be sure to get your spare from Honda or at least make sure it's T5 blank from Ilco.
Afrowookie
Jan 4, 2018 12:24 PM
HGSR2000
Aug 17, 2012 02:09 PM
88 civic ef
Jan 18, 2007 12:32 AM
