b16a Si tranny problem
Old Mar 25, 2005 | 09:56 AM
Super79Dave's Avatar
Default b16a Si tranny problem
Just installed b16 motorhave to take car elsewhere to fab up linkage however i can't get the transmission into nuetral. Anyone had this prob is there a way to get N without linkage. I don't want to take the axles out to tow the car out risk of damaging wheel bearings.
Old Mar 25, 2005 | 10:06 AM
coot_er's Avatar
Default Re: b16a Si tranny problem (Super79Dave)
wouldn't it be easier just to buy the linkage from hasport? anyhow maybe hook up you clutch cable and then try? it should make it easier.
Old Mar 25, 2005 | 10:36 AM
Crx Jimmy's Avatar
you can find linkage for $75, to find neutral jack the car up and have a buddy try to spin the wheels it should be hard if in gear, push the shaft all the way in and put a bolt or screwdriver through the hole so you have something to pull on and pull it out one notch at a time when the other person is spinning the wheels freely it is in neutral
Old Mar 25, 2005 | 01:38 PM
Default Re: b16a Si tranny problem (Crx Jimmy)
Ok first off everything is hooked up. engine runs clutch works adn everything spins properly. Done the screw driver in the linkage and still can't get nuetral i believe i've got 1st 3rd and 5th. Doesn't matter anyhow i just put the clutch in and pushed it out the door and onto the trailer.
Thanks anyway
dansnyder22
Transmission & Drivetrain
Sep 17, 2009 03:52 AM
hannslebo
May 6, 2009 04:37 AM
blue89hatch
Nov 24, 2008 11:14 PM
phatstyles
11
Mar 20, 2005 01:05 PM
It's*BOLO!!
15
Nov 30, 2002 10:16 PM
