a/f gauge stopped working when converted my car to obd1
Old Mar 25, 2005 | 09:14 AM
Boost3d22's Avatar
Default a/f gauge stopped working when converted my car to obd1
i had my a/f gauge running to the white wire on the o2 sensor on my down pipe, and it was working correctly, i put a jummper harness on my car with a p28 and uberdata and an afc2, and put obd1 clips and a resistor pack with my injectors, and then the a/f gauge stopped reading, i checked all the wires and even resoldered it, it is hooked up the same as when it was working...... is this a common problem? do i need to hook it up to my ecu or else where? or is there a problem with the gauge ( brand new) ? i am out of ideas on this one....
1997 prelude turbo - 15psi
Old Mar 25, 2005 | 10:52 AM
flip1199's Avatar
Default Re: a/f gauge stopped working when converted my car to obd1 (Boost3d22)
what gauge is it?
Old Mar 25, 2005 | 06:02 PM
Boost3d22's Avatar
Default Re: a/f gauge stopped working when converted my car to obd1 (flip1199)
its a phase a/f gauge i got from advanced auto parts because the apexi ones i had were stolen so i needed to get new gauges quick
Old Mar 25, 2005 | 06:12 PM
Firedrake's Avatar
My autometer gauge has always been on the thicker white wire near the ECU, and didn't have any problems after I converted to OBD1. You sure your gauge didn't just go bad or short out or something?
Old Mar 25, 2005 | 06:23 PM
The Phil's Avatar
Default Re: a/f gauge stopped working when converted my car to obd1 (Firedrake)
Get one of those variable voltage output whateverthehell things (i've got one in my basement if you need a pic, forgot what its called). Run through the 0-1 voltage range to make sure the gauge is working right.
abmerop18
Jul 21, 2009 01:16 PM
JDM_EK4_Coupe
Jun 19, 2007 03:49 PM
Mike813
Jun 4, 2004 08:28 AM
Defiant1999
Jan 5, 2002 07:10 AM
One8Hatch
Nov 30, 2001 05:10 PM
