how to wire vtec
Old Mar 25, 2005 | 09:08 AM
90crxmike's Avatar
Default how to wire vtec
hey i have a 90 crx and just a vtec head one and left it obd0 how do i wire vtec but not using the tach
Old Mar 25, 2005 | 09:18 AM
SiR Inspired ED7's Avatar
Default Re: how to wire vtec (90crxmike)
https://honda-tech.com/zerothread?id=919292
if this link dont help search i'm pretty sure there's topics under this title
Crx Jimmy's Avatar
get a pwo or pr3 ecu and hook it up use search for pinouts if you need
Old Mar 26, 2005 | 04:26 PM
90crxmike's Avatar
Default Re: how to wire vtec (Crx Jimmy)
ok i dont have the plugs that plug up to the plugs on the vtec sleinoid and can i still use my stock ecu
Old Mar 26, 2005 | 04:38 PM
str8boost's Avatar
u will need a pr3 ,i have for sale. ure pinouts are A8 VTS B5 VTPS B19 KS
u will need the plugs for the VTS and VTPS, and u have to ground the solenoid
K
Old Mar 26, 2005 | 04:54 PM
90crxmike's Avatar
Default Re: (str8boost)
i think i am going to wire it to the tach i heard its easier does any one know how to do that
Old Feb 7, 2006 | 07:05 AM
crxnj's Avatar
Default Re: (90crxmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxmike &raquo;</TD></TR><TR><TD CLASS="quote">i think i am going to wire it to the tach i heard its easier does any one know how to do that</TD></TR></TABLE>
You splice into the wire for the shift light..Then hook a wire from it to a 30 amp relay then from that to the vtec solenoid wire.,,and use the shift light stting as the rpm switch...Done..However if you dont have the correct fuel/timing maps for vtec it will feel no different..
civic_boy23
Feb 2, 2007 07:15 PM
Propulsion
Jul 22, 2003 12:47 PM
AussieK24
May 29, 2002 11:59 AM
