99 d16 into 95 coupe problem...pleae help!!!!
Old Mar 25, 2005 | 08:32 AM
I_LuvmyHonda's Avatar
Default 99 d16 into 95 coupe problem...pleae help!!!!
got the motor in...everytihing bolted up...motor cranks but no fire...i ran a tester to the two clips to the distributor and i am getting fire out of one(smaller clip) but not out of the other(larger clip)..whats the problem...somebody please help
Old Mar 25, 2005 | 01:19 PM
Default Re: 99 d16 into 95 coupe problem...pleae help!!!! (I_LuvmyHonda)
bump...anybody??...somebody...pleeeeeaaaasssee
Old Mar 25, 2005 | 03:35 PM
keepinitsimple's Avatar
u put some fresh spark plugs in there?...i had the starting issues as well...no spark, thought it was the distributer, in the end, it was a fouled spark plug
Old Mar 25, 2005 | 05:43 PM
Default Re: 99 d16 into 95 coupe problem...pleae help!!!! (keepinitsimple)
thanks for the input...although i dont see how it could be the spark plugs if theres no fire passing from the distributor...but i might go ahead and put some fresh plugs...see what happens...anybody else have any suggestions...all the help is greatly appreciated..thanks
Old Mar 26, 2005 | 10:51 AM
bump...spark plugs didnt work...anybody...at all...99 d16y7...with all d15 accessories and ecu...d15 manis...bolted in perfect abd cranks but no fire from the distributor...same distributor started the motor that i took it off from...any info would help...thanks
Old Mar 26, 2005 | 12:27 PM
Jdm91Teg's Avatar
you have it wired wrong for the distrubitor. two plugs on the car side and one on the distrubitor correct?
Old Mar 26, 2005 | 12:55 PM
i also recently swapped a y7 in my 95 hatch, i used all the parts from my z6 (manis, wiring harness, etc.) , but i used a obd-1 non vtec distrib that my friend had laying around, and slapped that on...
OBD-1 distrib has 2 connectors, Obd-2 has only 1
just use ur old distrib off the motor you took out of your coupe...
Modified by keepinitsimple at 3:37 AM 3/27/2005
Old Mar 28, 2005 | 06:25 AM
i did use the dist off the coupe..found problem...crackhead mechanic that installed the push start on the car cut into all sorts of ******* grounds...then used the twist and tape method...after pulling the harness and some extensive solder work i got fire...now no fuel...i think it might be the little washer for the filter to fuel rail line...theres not one on there and i think those little washers pass fuel(they have like grooved cuts in em)...should work right...if anybody else might know something let me know...thanks for the help
Modified by I_LuvmyHonda at 12:41 PM 3/28/2005
Sdaviswhodat
Jul 6, 2011 03:06 PM
lilmisshonda
Jun 30, 2008 09:49 PM
EJ ITO
May 15, 2008 07:01 PM
jchung
26
Mar 16, 2007 11:24 PM
