My friends car sounds like it has marbles?....
Old Mar 25, 2005 | 08:14 AM
UNDER PRESSURE's Avatar
Default My friends car sounds like it has marbles?....
As stated in the title, my friends car sounds like it has marbles... What could be causing this?...
TIA
balistik's Avatar
huh? a rattling noise?
Old Mar 25, 2005 | 08:16 AM
Default Re: (p28jspeceg6)
Yeah it's sounds like it has marbles in the engine, could it be running lean?...
Old Mar 25, 2005 | 08:17 AM
DJ_SaNdOz's Avatar
Default Re: (UNDER PRESSURE)
detonation will sound like rocks or marbles if it's bad.....
Old Mar 25, 2005 | 08:24 AM
AutoXer's Avatar
Default Re: (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">detonation will sound like rocks or marbles if it's bad.....</TD></TR></TABLE>
Rod knock as well, but it always sounds like marbles.
What motor? Could be on it's way out.
Old Mar 25, 2005 | 08:35 AM
Default Re: (EX_AutoXer)
Well my friend took the car to the shop and it came out worse... She said it sound like it has marbles I haven't looked at it I'm just trying to get some opinions on what it could be before I actually look at it.
TIA
Old Mar 25, 2005 | 08:44 AM
EE_Chris's Avatar
It sounds like detonation to me - I'd tell her to stop driving it before its time to replace the engine.
Why did she initially put her car into the shop?
Old Mar 25, 2005 | 09:10 AM
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like detonation to me - I'd tell her to stop driving it before its time to replace the engine.
Why did she initially put her car into the shop?</TD></TR></TABLE>
Well it's a friend of a friend so I'm not really sure... Let me find out and i'll post more info.
Old Mar 25, 2005 | 04:09 PM
93Civac's Avatar
Is she using cheap gas, could be spark knock.
Old Mar 25, 2005 | 04:14 PM
dohcVTECeg2's Avatar
Default Re: My friends car sounds like it has marbles?.... (UNDER PRESSURE)
its prolly that dinky single cam he has under the hood
Old Mar 25, 2005 | 04:49 PM
null.'s Avatar
Default Re: My friends car sounds like it has marbles?.... (dohcVTECeg2)
does the marble sound get louder the higher the rpm's are?
Old Mar 25, 2005 | 10:05 PM
Default Re: My friends car sounds like it has marbles?.... (eg6junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6junkie &raquo;</TD></TR><TR><TD CLASS="quote">does the marble sound get louder the higher the rpm's are?
Yup.
Old Mar 25, 2005 | 10:09 PM
null.'s Avatar
it's time to replace your rod bearings
Old Mar 25, 2005 | 10:37 PM
_BEN_'s Avatar
I had a dizzy go bad that sounded like it had marbles spinning around in it.
Old Sep 23, 2005 | 10:23 AM
pbink's Avatar
Default Re: My friends car sounds like it has marbles?.... (_BEN_)
i've got marbles in my **** too...only hear it at about 1/3 throttle in all gears. It's a cross between the sound of my car digesting marbles and almost a sputtering sound. I want to say I feel a slight loss of power too.
from what i can tell it's either...
ignition timing
belt timing off by a tooth or so
dizzy cap/rotor bad
valve lash needs adjusting
I'm leaning towards the timing because I feel a slight loss of power as well, and for some reason I just don't think it's the dizzy. I replaced my plugs/wires last week, so I know it's not that. I'll be posting results as soon as I do anything.
Old Sep 23, 2005 | 10:29 AM
violence_hero's Avatar
Default Re: My friends car sounds like it has marbles?.... (pbink)
A rattling sound at a certain rpm/throttle could definitely be the rod bearings. When mine went I only had the rattle part throttle (more if there was a load like an uphill). For the longest time I thought it was my exhaust rattling.
Old Sep 23, 2005 | 11:24 AM
pbink's Avatar
Default Re: My friends car sounds like it has marbles?.... (violence_hero)
well that sounds scarily close to my situation. hmm, anyone link to a good head removal post?
Old Sep 23, 2005 | 11:34 AM
JdmLub's Avatar
mine sounds like that only till it gets warmed up, any sugestion about this, same subject..
Old Sep 23, 2005 | 11:47 AM
oneforce's Avatar
Default Re: My friends car sounds like it has marbles?.... (JdmLub)
try a heavier oil, 20-50 or even a 40 or 50w..
Old Sep 23, 2005 | 11:53 AM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6junkie &raquo;</TD></TR><TR><TD CLASS="quote">it's time to replace your rod bearings</TD></TR></TABLE>
You are a moron. Do you have any idead how many different things this could be?
Leave.
Old Sep 23, 2005 | 01:00 PM
Sector9guy's Avatar
Default Re: My friends car sounds like it has marbles?.... (JDM-97CX)
No one's mentioned the possibility of bad Lost Motion Assemblies. Mine have been making the same noise you guys are describing for quite while now. Mine is a certain rpm rather than dependant on throttle. did a valve adj., checked timing, tried pulling the spark plugs to test for rod knock, and its still here. waiting on new lma's, but I'm almost certain that's what it is.
Old Sep 23, 2005 | 01:05 PM
Blind-Fashion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbink &raquo;</TD></TR><TR><TD CLASS="quote">i've got marbles in my **** too...only hear it at about 1/3 throttle in all gears. It's a cross between the sound of my car digesting marbles and almost a sputtering sound. I want to say I feel a slight loss of power too.
ignition timing
dizzy cap/rotor bad
I'm leaning towards the timing because I feel a slight loss of power as well, and for some reason I just don't think it's the dizzy. I replaced my plugs/wires last week, so I know it's not that. I'll be posting results as soon as I do anything.</TD></TR></TABLE>
Thats pre-detonation at its best, i would just run better gas!
Old Sep 23, 2005 | 03:10 PM
Anti-Drama Queens's Avatar
coudl just be valves ticking and need to adjust the valves...if its rod bearings, from a cold start...it will knock loudly
Old Sep 23, 2005 | 03:14 PM
undertheradar's Avatar
Default Re: (mr_ducksauce)
A bad cat can sound like it's got marbles in it as well. Can you locate where the sound is coming from?
Old Sep 23, 2005 | 03:16 PM
he says its from the engine
