rebuilding my gsr...what do you suggest?
Old Mar 25, 2005 | 07:26 AM
xstalkrx's Avatar
Default rebuilding my gsr...what do you suggest?
I believe some people up their compression when doing an engine rebuild? I read someone using type r pistons...what are the options for me if I'm looking to increase performance a little during my rebuild?
Old Mar 25, 2005 | 08:02 AM
Kendall's Avatar
P30/P72/PCT pistons as far as OEM upgrades are concerned. You could always spend the cash and get forged internals, but at the very least it's not a bad idea to invest in some ARP rod bolts.
Old Mar 25, 2005 | 08:04 AM
b18vtek's Avatar
Default Re: rebuilding my gsr...what do you suggest? (xstalkrx)
Type-R pistons and a aftermarket head gasket would raise your compression. I don't know to what ratio because their is diiferent kinds of Type-r pitons. That is good if you wanna stay n/a or nos(aftermarket rings are recommended for nos)
Old Mar 25, 2005 | 08:19 AM
WH0R3nEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xstalkrx &raquo;</TD></TR><TR><TD CLASS="quote">I believe some people up their compression when doing an engine rebuild? I read someone using type r pistons...what are the options for me if I'm looking to increase performance a little during my rebuild?</TD></TR></TABLE>
I know that civic type r pistons in a B16A will raise compression to 12.1. Im not positive if they'll work in a B18, but ask around.
Old Mar 25, 2005 | 09:25 AM
skunked's Avatar
Default Re: rebuilding my gsr...what do you suggest? (1SiKTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKTeG &raquo;</TD></TR><TR><TD CLASS="quote">
I know that civic type r pistons in a B16A will raise compression to 12.1. Im not positive if they'll work in a B18, but ask around.</TD></TR></TABLE>
Yeah they will. The USDM ITR piston is easy to get and will work fine. The P30 or JDM ITR pistons will bump the compression a little more. It just depends what your power goals are.
Old Mar 25, 2005 | 10:51 AM
r3v da t3g's Avatar
Default Re: rebuilding my gsr...what do you suggest? (skunked)
I have read p30 pistons up your compression to like 11:1 or somthing thats what i went with for my rebuild. I got p30 pistons, OEM Rods with ARP Rod Bolts
Old Mar 25, 2005 | 11:53 AM
-iLLuZioN-B18C1's Avatar
i use to have just jdm itr pistons in my gsr with dc headers...
according to my friend who drove my car...he said it pulls as strong as his.
he had...I/H/E lightweight flywheel intake mani
Old Mar 26, 2005 | 09:03 AM
xstalkrx's Avatar
the car needs more fuel with a higher compression rate right? so the ecu just automatically sends the extra fuel?
Old Mar 26, 2005 | 09:07 AM
AdamBOMB_STi's Avatar
i rebuilt my gsr with jdm itr pistons. comp is about 11.5-11.7, somewhere in the range. i bought new seals, gaskets, oil pump, timing belt, head studs etc. i used a stock 3 layer headgasket which worked fine. i highly recommend if u use itr, ctr, b16 pistons that you use invest in a fuel pressure regulator.
Old Mar 26, 2005 | 01:35 PM
xstalkrx's Avatar
how much extra power do you get out of the increased compression?
Old Mar 26, 2005 | 04:00 PM
95lstegman's Avatar
Default Re: (xstalkrx)
maybe 5hp if you're stock, way more if you got some big bump-sticks
Old Mar 26, 2005 | 07:11 PM
Demon R's Avatar
Default Re: (95lstegman)
I want to build up my teg too. I own a 95 gsr I want to set-up my car with a b16a head, CTR pistons, and skunk2 intake mani-fold. Is this a good set-up??? My goals is to beat a Type R.
Old Mar 27, 2005 | 07:53 PM
95lstegman's Avatar
Default Re: (b18c1ntegra95)
gonna need cams. and some tuning. and maybe some head work. i mean, you could get it done w/o that stuff, but it'll be a dyno queen, and w/o tuning it'll run like crap and perform the same.
vtec4max
22
Aug 6, 2007 04:32 PM
JDM_NA_eg6
Jan 10, 2006 08:29 PM
itrsleeper
Dec 6, 2005 10:33 PM
94gsr18kid
10
Jan 25, 2005 05:35 PM
ITR_1211
Jan 18, 2004 08:09 AM
