Harness Question?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maka »</TD></TR><TR><TD CLASS="quote">will i have to take apart the dash to put the harness in?</TD></TR></TABLE>
No, you're just swapping engine harnesses, not dash harnesses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maka »</TD></TR><TR><TD CLASS="quote">will i need anything in the ex harness? </TD></TR></TABLE>
Just use the stock Si engine harness from the B16A2. I can't remember if the Si computers have immobilizers or not, but if I were doing it, I'd convert to OBD-1 anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">
what are imobilizers?
i would say use the 96 EX harness and plug it up to the b16 and get the obd2a -> obd2b harness. i think this way will be more expensive tho. But you can most likely use the SI harness.
What i think he means by Imobilizer is that the ECU has an antitheft system that it recognizes from some type of chip embedded in the ignition key. I believe this might only apply to newer acuras
bayron
Oct 21, 2008 10:43 AM
