swap engine or change turbo?
Old Mar 25, 2005 | 01:27 AM
EG 4619's Avatar
Default swap engine or change turbo?
hi, i m driving a eg9.. but my turbo is spoil... now i am thinking either change a 2 litre engine or change turbo? i wan my car to be fast.. pls help
Old Mar 25, 2005 | 01:30 AM
Tad's Avatar
Tad
woah, be prepared for some harsh replies.
But i'll just say my part,
we could use some more details and clarity on what you mean exactly.
it's alittle hard to understand you.
Old Mar 25, 2005 | 03:07 AM
ironlung78's Avatar
Default Re: swap engine or change turbo? (EG 4619)
all that work to get a turbo and now you want to get rid of it, coming from a person with 1 post..
Old Mar 25, 2005 | 05:00 AM
Eyes Only's Avatar
Default Re: swap engine or change turbo? (sidesi)
just keep the turbo and work on it
Old Mar 25, 2005 | 05:08 AM
EG 4619's Avatar
thanks.. but using back my turbo will be better.. cause my current engine is B16A. but the setup for my turbo is sucks!!!
Old Mar 25, 2005 | 05:25 AM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG 4619 &raquo;</TD></TR><TR><TD CLASS="quote">thanks.. but using back my turbo will be better.. cause my current engine is B16A. but the setup for my turbo is sucks!!!</TD></TR></TABLE>
why is it suck? need more info on your setup.
Old Mar 25, 2005 | 05:28 AM
EG 4619's Avatar
do u have any info?.. or i should change my engine to b20? if i use back turbo, can i win a car w/ b20 engine?
Old Mar 25, 2005 | 05:38 AM
modedicebox's Avatar
wtf? me no understand
Old Mar 25, 2005 | 05:44 AM
EG 4619's Avatar
Default Re: swap engine or change turbo? (modedicebox)
hmm.. sorry i no good at talking.. ah.. my car is setup with turbo but now the turbo is spoil.. i was thinking should i change a 2 litre engine or replace a new turbo... but i want to be fast too.. pls help!
Old Mar 25, 2005 | 05:50 AM
HiProfile's Avatar
Default Re: swap engine or change turbo? (2lua)
Instead of spending cash on a different motor and trying to sell the old one, get turbo cams and/or a different turbo. A bigger t3/t04 or a precesion turbo would be perfect, assuming you're already using a turbo with a t3 flange.
As for your 2nd fscked up post, I'm assuming that when you say "if i use back turbo, can i win a car w/ b20 engine?" you mean if you use the same turbo, will you have a fast b20. If the turbo isn't big enough for the b16, it will be even worse on a b20. People have managed well over 300hp on stock b16's, and with high-lift short-duration turbo cams, you may not have to change anything else. Otherwise, sell that turbo and spend the cash on a much better unit.
edit: reading your 3rd post - I don't think you should be modding your car. If all you know about your vehicle is that "your turbo is spoil" and it has a b16, you need to do much more research. If you could tell us WHAT TYPE OF TURBO you have, WHAT BRAND/TYPE OF MANIFOLD you have, WHAT SIZE YOUR DOWNPIPE & EXHAUST is, maybe we can be more helpful. Otherwise we can't say much more than 'me likey big turbo, they non spoil, you get now'
Modified by HiProfile at 7:03 AM 3/25/2005
Old Mar 25, 2005 | 05:54 AM
EG 4619's Avatar
Default Re: swap engine or change turbo? (HiProfile)
thanks.. what better unit u mean? hmm... cause most my friend ask mi to change to 2 litre cause is much faster den using bigger turbo and turbo wont last.. issit true?
Old Mar 25, 2005 | 06:04 AM
HiProfile's Avatar
Read my previous edit and post that info. As for what your friends do and say, a well oiled & cooled turbo combined with you letting it warm up and cool down properly will stay in great condition for a LONG time. It also won't matter how big or small the turbo is - if you treat a turbo like ****, it won't last long.
I'll tell you this. If the two options you're looking at are A) <u>getting a b20 and re-using your current turbo kit</u> and B) <u>keeping your b16 and swapping in a bigger turbo</u>, you'll have even more problems with choice A). The reason is that you still can't feed that turbo enough air, and it will still suck.
Yes a b20 is usually a better daily driver since it makes much more torque when not making any boost, but for racing, b20's tend to make more power at low rpm's than street tires can take. The other point is that a b20 can't take as much boost as a B16 since it has much thinner sleeves. The b16 has higher stock compression, but it also has much tougher rods.
Old Mar 25, 2005 | 06:18 AM
Neutex22's Avatar
Me liky nitorus wit trubo. Ungabunga me go get fast and win.
Old Mar 25, 2005 | 06:24 AM
PhoebeusFenix's Avatar
English? Its like reading when your drunk, you ask WTF was this guy thinking?
LogicMotorsports.com
Sep 28, 2011 11:48 AM
louisiana CRX
Dec 1, 2008 04:11 PM
project142
Dec 22, 2003 04:13 PM
deeweezy
Apr 26, 2003 06:12 PM
