shaved door handels...door opens when you push on the side mirror, possible?
Old Mar 24, 2005 | 08:11 PM
91sicrxer's Avatar
Default shaved door handels...door opens when you push on the side mirror, possible?
basically the title of this topic is what i'm saying...i wanted to shave my door handels and not use poppers, for some reason i just don't like them...i feel that pushing on the side mirrors and rigging something up in the door to open it would be a lot cooler...anyone agree, or have ideas, seen a car with that or anything to help would be fant-fooking-tasic...
Old Mar 24, 2005 | 08:17 PM
HatchMo's Avatar
Default Re: shaved door handels...door opens when you push on the side mirror, possible? (91sicrxer)
thats a retarded idea sorry man
Old Mar 24, 2005 | 08:26 PM
91sicrxer's Avatar
Default Re: shaved door handels...door opens when you push on the side mirror, possible? (HatchMo)
how is that a bad idea, have you heard of it being done before? i would say that's completely original and very few if no people have done it... and it would be more reliable that poppers, that's just what i think...i guess my opinion doesn't matter for my car?
Old Mar 24, 2005 | 08:31 PM
CRX_1.8T's Avatar
Yeah that is a pretty unique idea. I would just be worried about random people accidently bumping into your mirrors in a parking lot and seeing the door go *thunk* and open for them. Yeah your opipion matters dude, but you did ask us. If you want a different way to open your door, maybe rig up a hidden button or something on the undercarriage or something. I dunno, I would never do it, but hey it is your car and really that is all that matters.
Old Mar 24, 2005 | 08:36 PM
91sicrxer's Avatar
Default Re: shaved door handels...door opens when you push on the side mirror, possible? (CRX_1.8T)
yeah i thought about that too (people bumping into the mirrors) but i am getting a viper alarm system put in that you lock the doors with the remote...i was thinking i could still lock it up and the door shouldn't open? you think that might work?
Old Mar 24, 2005 | 08:37 PM
JDMorgan's Avatar
by poppers you mean the spring loaded thing right?
i have 2 friends with shaved handles and neither use the spring loaded pieces that open the door for you. the porsche opens around 1/4 the way on its own, the accord opens enough to fit your hand in the jamb and open it. if you mean no solonoid(hides inside door) then you are just doing a cheap job.
once you have a solonoid in the door you can mount the button anywhere including inside the mirror.
Old Mar 24, 2005 | 09:06 PM
RCautoworks's Avatar
Default Re: shaved door handels...door opens when you push on the side mirror, possible? (KraZEtEggIE)
You would have to rid some type of pulley system up, because it would not be a straight shot at the door. But now that I think about it, if you take the mirror cover off and you move the mirrow, nothing really moves on the inside. So it might not be possible.
Old Mar 24, 2005 | 09:14 PM
b16_madman's Avatar
Default Re: shaved door handels...door opens when you push on the side mirror, possible? (90blackcrx)
sounds cool, i just like handles w/out keyholes
Old Mar 24, 2005 | 10:59 PM
gutterslide's Avatar
Default Re: shaved door handels...door opens when you push on the side mirror, possible? (B16_madman)
make it happen.
Old Mar 25, 2005 | 12:58 AM
davens's Avatar
It would actually be pretty easy if you used a popper. Just wire the solenoid to be activated by a small momentary pin sized button. Place the button somewhere in the mirror housing. Make sure placement is hard to see, more feel...like under the top lip of the housing .
Old Mar 25, 2005 | 01:52 AM
NikoZai's Avatar
Default Re: (davens)
Not a bad idea, very original. I think you would wear out the mirror after a year.
Gotta get creative, i can't figure out how you would make the mirror trigger it.. (where to mount the switch/pin/whatever) there must be a place inside the mirror BUT only the power mirrors have a hole into the mirror to run the 2 wires.
I hope you know electronics well and all your options, and i hope you have some kinda alarm and a system of checks and balances so that joe shmoe can't open the car. Like making the alarm disable the unlock/pop mechanism. You would do that the same way as the alarms fuel pump kill is setup.
http://www.the12volt.com for vehicle electronics knowledge.
Old Mar 25, 2005 | 04:54 AM
davens's Avatar
Default Re: (NikoZai)
I was thinking a button that requires very little space like this:
Mounted something like this:
I've been toying with a similar button idea as a back up for my automatic locks after I "shave" the outside keyholes.
Old Mar 25, 2005 | 05:00 AM
WhatThaFrig's Avatar
If you are getting an alarm,why not use the remote to pop the doors?
Old Mar 25, 2005 | 05:01 AM
quis23's Avatar
creativity
Old Mar 25, 2005 | 06:05 AM
boosted_hatch_216's Avatar
Default Re: (quis23)
hes got the right idea. itd suck to have your battery die and the only way to get in be by your remote.
Old Mar 25, 2005 | 07:22 AM
redzcstandardhatch's Avatar
something different
or you could just go in through the hatch-no big deal.
Old Mar 25, 2005 | 08:36 AM
Custom Rex's Avatar
Default Re: (redzcstandardhatch)
I have seen a Black CRX here in toronto with this exact mod., he had power locks and he had used a wire cable to pull the release on the handle when he pulled the mirrior in. worked like a charm.
Old Mar 25, 2005 | 08:53 AM
riceisnicenv's Avatar
Default Re: (Custom Rex)
i smell theft...
Old Mar 25, 2005 | 09:28 AM
Wes V's Avatar
Default Re: (riceisnicenv)
You could also do what the low-riders used to do and hide a switch in the fender well. Just get a "sealed" switch from a boat supply.
Wes
Old Mar 25, 2005 | 10:23 AM
civhatch90's Avatar
somebody curious enough is gonna see that button next to the mirror and either they will destroy it or steal it
Old Mar 25, 2005 | 10:49 AM
b16sellout's Avatar
Default Re: (civhatch90)
I'm a little fuzzy on your ideas, are you saying push on the reflective lense or put on the mirror's housing towards the door? Also, do you want to have shaved door handles or just the key hole? If you've still got handles you could just use a solenoid to unlock the doors via the mirror, but if you dont' have handles wouldn't it require poppers? I mean how else would you open the door locked or not?
Old Mar 26, 2005 | 04:14 PM
91sicrxer's Avatar
Default Re: (b16sellout)
this is what i want to do...shave the handles and key holes, rig something up like how the door would open originally (lever, pulley, whatever) but with the mirror so when i push on the whole side mirror the door will open...the side mirror would act like a door handle...then have my alarm system lock and unlock my doors (which means i also need to get automatic locks instead of the manual locks)...i don't know how the **** this is going to work this is just an idea...if anyone knows how this is would work or anything like that let me know b/c this is just an idea in my head and i wanted to put it to work
Old Mar 26, 2005 | 04:48 PM
h22_cx_hatch's Avatar
Default Re: (91sicrxer)
just look inside your door and find a custom way to make it work- like leverage. or like it might work sort of like when u raise a basketball net. springs and a bungee-cord thats really strong. my idea might not work though. if you do go with the whole mirror idea, u might have to get a custom side mirror
Old Mar 26, 2005 | 07:30 PM
1988c-rex's Avatar
u could always put it in the back of your car, my friend has it where he sticks his key in the hatch keyhole and it hits his button to open his door. But he also has poppers though
Old Mar 26, 2005 | 07:36 PM
KFBhonda's Avatar
or get one of those fingerprint readers for computer security and rig it up to open with your fingerprint only. now that would be sick and slick.
