turn signal housing
Old Mar 24, 2005 | 07:57 PM
Showtime_III's Avatar
Default turn signal housing
alright so i have new turn signal housings. my right side just unscrewed and popped right out. however, i think the left side is either jammed or it was not put in properly. im thinking i can wedge it out, but im afriad of applying too much presure.
ideas?????
Old Mar 25, 2005 | 08:23 AM
PrettyLude's Avatar
kinda wiggle it, and it will pop out
Old Mar 25, 2005 | 08:50 AM
Default Re: (PrettyLude)
i did that...that think is STUCK. any other ideas man?
Old Mar 25, 2005 | 04:24 PM
Brodie53's Avatar
Default Re: (Showtime_III)
One of my turn signals is the the exact same way. You turn and turn the screw but it doesn't pop out. What I do is reach in through the bumper with an allen key and pop the screw out from the back end. I think the problem is with the speed clip which the screw goes into, the screw isn't actually gripping and just spins in place. I'm not sure if this is the same problem you're having.
Old Mar 25, 2005 | 06:28 PM
Default Re: (Brodie53)
thanx for the advice, but im having problems with the 1st light. i cant seem to get the hook out
Old Apr 8, 2005 | 04:52 PM
i finally gave up and brought my car to a body shop to put in the light housings. turns out that the previous owner broke the bracked that the housing sat in, so instead of fixing it, they glued it in. but thanx for the help guys.
Acethriller
Lighting
Jan 4, 2014 07:58 PM
MrGiggles
Apr 14, 2011 12:53 PM
mr.bronx75
Lighting
Jan 27, 2008 08:50 AM
g2b2
16
Jun 6, 2007 12:46 AM
SaTownTegGsr
Aug 20, 2004 11:45 PM
