Help install foglights
Old Mar 24, 2005 | 07:30 PM
aeon's Avatar
Default Help install foglights
Well I just got my foglights in and I'm having trouble installing it. I've looked at couple articles on HT and Team-Integra but I think the harness that came with my foglight are a little different then the ones that are in the articles.
This picture shows part of the harness connected to one of the foglights.
This is the other part of the harness which i believe connects under the dash.
Now let me know if I'm doing this correctly. I connected the plug from the first pic to a harness plug that was in the engine next to the driver side headlight.
From the second picture, the brown plug, does that go to this harness under the dash?
and from pic one, the wire i listed as unknown, does that go to the fuse like below?
I've connected everything this way and the foglights still don't work. Not sure if i connected the ground wires correctly, but i just screwed them down to any bolt i found that was connected to metal.. Let me know what I'm doing wrong here.
thanks.
Old Mar 24, 2005 | 08:09 PM
BolivianDc2's Avatar
Default Re: Help install foglights (aeon)
wow, you got the whole harness? nice! im going to sleep but im sure somebody can help you
Old Mar 25, 2005 | 12:11 AM
aeon's Avatar
anyone??
Old Mar 25, 2005 | 07:22 AM
aeon's Avatar
need some help....
Old Mar 25, 2005 | 08:30 AM
Default Re: (aeon)
whats is your email, i'll send you a copy of the OEM instructions
Old Mar 25, 2005 | 09:25 AM
SonicBlueTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">Well I just got my foglights in and I'm having trouble installing it. I've looked at couple articles on HT and Team-Integra but I think the harness that came with my foglight are a little different then the ones that are in the articles.
plugs into the one pin brown connector behind the blue capped windshield squirter reservoir.. the C shaped thingie is a ground... connect that to a bolt on the body of the car somewhere..
under dash harness does plug into the little brown plug under and behind the fuse box..
um.. looks at pictures more.. hhm.. err.. brb i'll go look at my teg..
Old Mar 25, 2005 | 09:44 AM
Default Re: (BolivianDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">whats is your email, i'll send you a copy of the OEM instructions </TD></TR></TABLE>
hey there u go.. even better..
Old Mar 25, 2005 | 10:45 AM
BigDaddyRich's Avatar
thats awesome... where can I pick up an OEM fog kit? I installed JDM fog kit for my friends 00 Si, but I havent seen them for an Integra
Old Mar 25, 2005 | 11:27 AM
LANEVOIX's Avatar
Default Re: (BigDaddyRich)
yeah same here...i would like to know...
Old Mar 25, 2005 | 05:55 PM
aeon's Avatar
I bought mines off a member here on HT.
Old Mar 27, 2005 | 01:51 PM
95greenteg's Avatar
Default Re: (aeon)
How r u doing with the install? You have the whole harness already done up for you...That black box is your relay which you should just screw in somewhere under your dash...That fuse box thing you also need...It would prob be easier to cut and resplice things and start over using one of the posted instructions...Mike M has a good how to on here...You just have to study it for a while...I studied that DIY until I knew what everything was and its purpose...Take your time and it should come out fine...
Old Mar 27, 2005 | 04:38 PM
aeon's Avatar
yeah i got it work, everything was pretty much plug and play. the first time i installed it, for some reason it didn't work but then i went back and tried it again and it lights up now. only problem was that one bulb was blown so i had to replace that.
now i have another problem, the light on the switch doesn't light on when the switch is turned on. anyone know how to fix this problem?
Modified by aeon at 9:24 PM 3/27/2005
Old Mar 27, 2005 | 06:08 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (aeon)
glad to see you got them installed and working
again sorry about the blown bulb, they both worked when i took them off the car
wishing i dindt sell them now as i jus picked up another 94 integra and i would love to have a set for myself
brian
Old Mar 27, 2005 | 07:27 PM
Default Re: (coptzer)
right click save target as for the instructions
http://www.we-todd-did-racing....DE%3D
yea, too lazy to send a copy to everyone who asked for it
Old Mar 27, 2005 | 08:19 PM
aeon's Avatar
Nice thanks for the link... i'll keep it for future references.
Old Mar 27, 2005 | 08:29 PM
aeon's Avatar
hey.. what program do i need to view that file? it opens up in adobe photoshop on my computer and i only get page 1 of 12
Old Mar 27, 2005 | 09:06 PM
Taristin's Avatar
What is it? A PDF? Try Adobe Acrobat?
Old Mar 27, 2005 | 09:15 PM
aeon's Avatar
Default Re: (Raa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Raa &raquo;</TD></TR><TR><TD CLASS="quote">What is it? A PDF? Try Adobe Acrobat?</TD></TR></TABLE>
tried it already. it in .tif format
Old Mar 27, 2005 | 09:36 PM
95greenteg's Avatar
Default Re: (aeon)
tried it already. it in .tif format</TD></TR></TABLE>
try a photo viewer or windows photo and fax viewer...
Old Mar 27, 2005 | 10:00 PM
aeon's Avatar
i still only get one page... which is a list of all the items you need for the installation
Old Mar 28, 2005 | 07:10 AM
95greenteg's Avatar
Default Re: (aeon)
oh yeah...That's all it's supposed to be...
Old Mar 28, 2005 | 08:03 AM
aeon's Avatar
oh, i thought it was the whole instructions on how to install the foglights...
Old Mar 28, 2005 | 09:27 AM
sleepyIntegra's Avatar
It's about the switch light.
OK. check to see if you have a OEM fog. If yes, something is wrong with the switch. If no (aftermarket), then it comes this way.
I have a brand new aftermarket and it's doing the same thing.
Old Mar 28, 2005 | 09:50 AM
DeadLock23's Avatar
i have an OEM switch, i got it on ebay, when I wired it up the green light didnt go on, take out the switch and replace the inner bulb, that you can get at Radio Shack, it has like a green covering to make the light green, same bulbs used in the hazard and defrost buttons.
there is like 2 wires that need to be routed around a path and then the bulb will work.
most likely its the same situation, just need a new inner bulb.
92eghatch13
Jan 18, 2015 07:45 AM
Jonknee
11
May 27, 2014 12:14 PM
type r 01-1063
Dec 10, 2003 02:00 PM
