rattle sound? gas milage?
Old Mar 24, 2005 | 04:40 PM
ca_delsol's Avatar
Default rattle sound? gas milage?
hey guyz...
2 questions if anyone can help me out.. i got a del sol 94 - manual trans
1) there was a weird rattle like sound when i hit 2500 rmps.. but now its getting louder.. and its not restricted to that rmp n e more.. it just happens ususally all the time.. very annoying.. i checked out the exaust and its not that.. n e suggestions?
2) my car used to give me up to 350-400 on a full tank... now i can barely pull off 300 and thats highway miles... i drive from michigan to newyork alot.. and i seem to be using up a bit too much gas.. tried some of those fuel injectors... but nothing seems to work.. n e ideas?
thanks in advance
ca
Old Mar 25, 2005 | 12:32 PM
ca_delsol's Avatar
n e 1?
Old Mar 25, 2005 | 01:40 PM
Relic1's Avatar
1) rattle at 2500rpm is usually the heat shield, it's not easy to see. crawl under the car and tap the exhaust, you'll see/hear it.
2) your O2 may be going bad.
have you done a tune up?
(new air filter, fuel filter, cap/rotor, plug wires, plugs)
"I tried some of those fuel injectors" - what? do you mean fuel injector cleaner?
or you replaced the fuel injectors?
Old Mar 25, 2005 | 01:59 PM
dohc notec's Avatar
Default Re: (Relic1)
the rattle sound is probably the engine pinging. check the timing, tune it up, check the O2 sensors and try a higher grade of gas
Old Mar 25, 2005 | 02:03 PM
OverCorrupt's Avatar
Default Re: rattle sound? gas milage? (ca_delsol)
i had a problem in my truck... it turned out being U-joints worn to ****... check that... can also cause vibration thru the car at higher speeds or even at lower speeds...
Old Mar 26, 2005 | 12:43 PM
dohc notec's Avatar
Default Re: rattle sound? gas milage? (OverCorrupt)
FWD cars dont have U joints
Old Mar 26, 2005 | 12:49 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: rattle sound? gas milage? (dohc notec)
Probably the heat sheild someplace. And yea, replace the O2 sensor(s) and do a tune up.
Old Mar 26, 2005 | 01:29 PM
clint g's Avatar
Default Re: rattle sound? gas milage? (JDM_Ej)
Good advice I was having the same problemo
BKJJ77
Mar 5, 2012 08:41 AM
DAintegraGSR
May 1, 2011 09:24 PM
1clean_ Ej
Mar 29, 2007 10:00 PM
crxforum
Mar 4, 2006 03:24 AM
jdadams12
Dec 27, 2005 10:53 PM
