will 205/45-16 fit on 2001 integra ls?
Old Mar 24, 2005 | 03:22 PM
skiwithcars's Avatar
Default will 205/45-16 fit on 2001 integra ls?
will 205/45-16 fit on 2001 integra ls? im pretty sure they will, but they are on my 99 civic 4dr now and might be putting them on the teg. and how wide can u go on a teg, i know 205 is biggest on civic?
Old Mar 24, 2005 | 03:39 PM
tilt's Avatar
Default Re: will 205/45-16 fit on 2001 integra ls? (skiwithcars)
With proper offset and suspension, yes.
I have 215/45/16 azenis on 16x7.5" +40 offset wheels. Eibach Pro-kits 1.3" drop, no camber kit. I had to remove the rear lip liners but otherwise it works fine.
Old Mar 24, 2005 | 04:17 PM
Default Re: will 205/45-16 fit on 2001 integra ls? (tilt)
thanks
Old Mar 24, 2005 | 04:30 PM
SonicBlueTeg's Avatar
they will fit.. i run 205/45/16s on my teg daily and 205/50/15s for track fun.. my current setup & drop won't allow 215's due to rubbing..
Old Mar 24, 2005 | 04:58 PM
BlueIntegraBoy's Avatar
I am running 205/50/15s with +42 offset on my EG. No rubbing at all.
Old Mar 24, 2005 | 05:37 PM
integra-evan's Avatar
Yes, they will fit. That is actually the best tire size to put on (with a 16" rim) to keep your speedometer accurate.
Old Mar 24, 2005 | 06:59 PM
Chris F's Avatar
Default Re: will 205/45-16 fit on 2001 integra ls? (SonicBlueTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicBlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">they will fit.. i run 205/45/16s on my teg daily and 205/50/15s for track fun.. my current setup & drop won't allow 215's due to rubbing.. </TD></TR></TABLE>
Wow, yep, that about sums me up too.
Old Mar 24, 2005 | 07:20 PM
riceball777's Avatar
the correct size to run on a integra is
195/60/14
195/55/15
205/45/16
205/40/17
Old Mar 24, 2005 | 07:23 PM
Default Re: will 205/45-16 fit on 2001 integra ls? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">the correct size to run on a integra is
195/60/14
195/55/15
205/45/16
205/40/17</TD></TR></TABLE>
Also, 205/50/15 will work in place of 195/55/15
Old Mar 24, 2005 | 08:40 PM
iH8RICERZ's Avatar
Default Re: will 205/45-16 fit on 2001 integra ls? (integra-evan)
i have 205/45/16's on my teggy
and my car is lower now...if i hit a big dip in the road, it does rub, when i'm on the throttle in a rough turn, it rubs.. but for daily normal driving, it doesnt rub
blindguy
11
Oct 1, 2008 08:09 PM
y0whuddupb
Apr 7, 2006 11:15 AM
JDMG3
Mar 21, 2006 01:03 PM
fastwanabe
27
Aug 11, 2003 01:51 PM
sfr4dr
Apr 17, 2003 08:10 PM
