Is it possible to shave a +40 offset wheel 5mm to be +45?
Old Mar 24, 2005 | 01:38 PM
Alexander's Avatar
Default Is it possible to shave a +40 offset wheel 5mm to be +45?
I have four +45 offset rota slips. One is slightly bent. I can get my hands on a replacement wheel but it is +40 offset.
Can i take it to a shop to shave off 5mm from the back of the mounting point of the wheel?
Or will having one wheel sticking out 5mm more be so negligable that it wouldn't really matter?
EDIT: Fixed the post, I switched around the offsets.
Modified by Alexander at 9:10 AM 3/25/2005
Old Mar 24, 2005 | 09:55 PM
XrcR6's Avatar
Default Re: Is it possible to shave a +40 offset wheel 5mm to be +45? (Alexander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alexander &raquo;</TD></TR><TR><TD CLASS="quote">I have four +40 offset rota slips. One is slightly bent. I can get my hands on a replacement wheel but it is +45 offset.
Or will having one wheel sticking out 5mm more be so negligable that it wouldn't really matter?</TD></TR></TABLE>
EDIT: Re-reading, your title is asking one thing and the post is asking another...
This applies to the post:
I think you are thinking about it backwards... Provided all the rims are the same width, a +45 rim is going to be 5mm closer to the inboard/suspension side than your +40's are. You can just add a 5mm spacer to push it outboard and make it match the other three.
Modified by XrcR6 at 11:05 PM 3/24/2005
Old Mar 25, 2005 | 12:20 AM
B2FiNiTY's Avatar
Exactly. Just get a 5mm spacer.
Old Mar 25, 2005 | 05:10 AM
Alexander's Avatar
Default Re: Is it possible to shave a +40 offset wheel 5mm to be +45? (B2FiNiTY)
I'm an idiot.
Fixed the post.
My slips are currently +45, and the one i'm getting is +40... I could get three spacers for the other wheels but a little weary of runing spaces in the first place.
Old Mar 25, 2005 | 06:30 AM
ek_da_car's Avatar
if the replacement is 40et then to get it to 45 <U>you have to shave off 5mm</U> adding a 5mm spacer to a 40 offset wheel will bring it to 35et. the poster ir correct with his assumption... a shop can shave it for you but consult them to whether its safe to do it... btw, slips came in a 45et? hmmm didnt know that...
Old Mar 25, 2005 | 10:30 AM
Holding monSteR's Avatar
Default Re: Is it possible to shave a +40 offset wheel 5mm to be +45? (ek_da_car)
they did in 16" for sure.
Old Mar 25, 2005 | 02:40 PM
XrcR6's Avatar
OK makes sense now... Yeah machine shop or a wheel repair shop (someplace with a lathe that knows how to use it, etc.) should be able to handle shaving the one wheel down.
Some manufacturers start out casting a wheel with a thick hub mounting face and during the finishing process, machine it to varying offsets. Saves having to have separate castings for each offset.
theloxmyth
Nov 18, 2008 10:55 AM
Ponyboy
Apr 15, 2007 12:39 PM
typeR564
Honda Fit
Jul 19, 2006 01:54 PM
spyz34
May 25, 2004 09:08 PM
