Speedbleeder fitment for clutch
i've used a piece of vacuum line before. open the bleeder and put a piece of vacuum line on the end . put the other end in a bottle of brake fluid, then with your hand push the clutch pedal and then pull it back up several times. make sure you keep the resivior full. that should bleed the system. or you can gravity bleed it, where you open the bleeder and just let it sit dripping for a while. still insure the resivior never empties. either will work. i prefer the vakuum line method though.
