tire size question for gsr w/ oem r suspension
Old Mar 24, 2005 | 12:16 PM
tweekerz's Avatar
Default tire size question for gsr w/ oem r suspension
Hey guys, have a dc2 gsr w/ suspension from a 01 R & oem R lca's. I have rota slipstreams in 16x7 w/ 40mm offset. What tire size would you guys run to give proper clearance, no rubbing, etc??
Thanks!
Old Mar 24, 2005 | 12:18 PM
Bbasso's Avatar
Default Re: tire size question for gsr w/ oem r suspension (Tweekerz)
Have you asked here?
Wheel and Tire Forum
Wheel and tire related discussion. New!
Old Mar 24, 2005 | 12:20 PM
IGGY's Avatar
Default Re: tire size question for gsr w/ oem r suspension (Bbasso)
Maybe the GSR page.
Old Mar 24, 2005 | 12:26 PM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Have you asked here?
Wheel and tire related discussion. New!</TD></TR></TABLE>
ill try thanks
Old Mar 24, 2005 | 01:12 PM
p nut's Avatar
I'm guessing 215/45 or 205/45 would both work fine.
Old Mar 24, 2005 | 01:15 PM
Big Phat R's Avatar
205/45-16 is basically your safest choice.
(215/45-15 are very rare size - v. little comes in that size)
Old Mar 24, 2005 | 01:19 PM
Chris F's Avatar
Default Re: tire size question for gsr w/ oem r suspension (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">205/45-16 is basically your safest choice.
I've run that size with stock ITR suspension and +38 offset, no issues. With the +40 offset, you're probably fine with a 215/45 or 215/40.
My snow tires were 205/50R16, that was pushing it. Then I lowered my car and they're mostly unusable.
Good luck!
-Chris
Old Mar 24, 2005 | 01:27 PM
shhh151's Avatar
Default Re: tire size question for gsr w/ oem r suspension (Chris F)
will the 215/55/16 fit?
Old Mar 24, 2005 | 01:31 PM
Chris F's Avatar
Default Re: tire size question for gsr w/ oem r suspension (GSR515)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR515 &raquo;</TD></TR><TR><TD CLASS="quote">will the 215/55/16 fit?</TD></TR></TABLE>
Zero chance. that would not fit (it would likely rub the inside of the wheel well, and be horribly too tall in general)
215/45 would fit.
Old Mar 24, 2005 | 01:46 PM
shhh151's Avatar
what about 205/50/16
Old Mar 24, 2005 | 01:47 PM
p nut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
215/45 would fit.</TD></TR></TABLE>
Your speedo would be off by quite a bit, also.
Old Mar 24, 2005 | 01:48 PM
shhh151's Avatar
Default Re: (P Nut)
duh
Old Mar 24, 2005 | 01:51 PM
p nut's Avatar
Default Re: (GSR515)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR515 &raquo;</TD></TR><TR><TD CLASS="quote">duh</TD></TR></TABLE>
Just trying to help you out, dipshit.
And, btw, this isn't 20 questions.
Old Mar 24, 2005 | 02:08 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR515 &raquo;</TD></TR><TR><TD CLASS="quote">what about 205/50/16</TD></TR></TABLE>
I have a set. They rubbed with stock ITR suspension, just a little bit. I lowered it and they're unusable.
There is no reason to get a taller tire than stock, unless you're getting it used and super cheap.
p.s. Read. I answered your question before you even posted it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">My snow tires were 205/50R16, that was pushing it. Then I lowered my car and they're mostly unusable.
-Chris
xkrntamax
Jul 12, 2007 08:52 PM
No2Pencil
Apr 6, 2007 06:47 PM
member EG
Feb 5, 2007 12:14 PM
g3teg97
May 15, 2006 08:16 PM
tweekerz
Mar 24, 2005 03:25 PM
