help changing front light bulb.
hey guys i just got this car and no manual. i know this is a dumb question but how do you change the front light bulb? i think its the h1 halogen main fog light, the one thats skinny and long. there is a rubber piece around it, do i have to take it out? after that there is screws and a thin metal piece that is holding, what i think is the bulb in place, should i unscrew those? why would they make it so hard to change a bulb? please help ASAP.
thanks in advance
thanks in advance
1) Disconnect the plug from the bulb socket.
2) Remove the rubber thing.
3) Push the thin metal toward you, then push left or right.
4) You should be able to pull out the socket that's holding the bulb.
Do the opposite after you're done.
animated_life
Dec 27, 2003 12:03 PM
