street all motor ls
everyone with decent street all motor ls projects please say what your set up is becuase i would like to know, so far i got all new bearings and gaskets, head milled, arp head studs, cams, and i want to get new injectors(maybe like prelude injectors), flywheel(what is too light for a flywhee)?, stg 2 act clutch, and also probably a b16 tranny.....oh yeah and a safc too. does anyone have any recomendations about valve springs and retainers and also where could i get new valves, valve springs, and retainers. thanks for all ya'll help in advance
go to inline4.com or summit-racing equipment and get Crower Valvesprings, they are only $185 on these 2 sites. Also I use factory retainers b/c they are stronger than Ti retainers and I dont plan on going over 8500 rpm so Im not worried about lightweight.
Click on "MY SETUP AND DYNO" in my sig. It doesnt look like a link but it is!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">so if you build a ls and keep the factory retainers, you could rev to say 8000 on that head?</TD></TR></TABLE>
I do no problems! I the B16 revs to 8200 with no problems on factory retainers, and they are made of the same material(retainers).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">
I do no problems! I the B16 revs to 8200 with no problems on factory retainers, and they are made of the same material(retainers).</TD></TR></TABLE>
well that just suptracted some $$$$ off my build
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the DA in HONDA »</TD></TR><TR><TD CLASS="quote">thanks yeah i will be buying those valve springs</TD></TR></TABLE>
well that just suptracted some $$$$ off my build </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the DA in HONDA »</TD></TR><TR><TD CLASS="quote">its actually inlinefour.com and i think the other one is summit-racing.com</TD></TR></TABLE>
i know both sites
i just cant find the exact product>
i know both sites
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">I do no problems! I the B16 revs to 8200 with no problems on factory retainers, and they are made of the same material(retainers).</TD></TR></TABLE>
I also run stock retainers and crower springs with big LS cams with no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 »</TD></TR><TR><TD CLASS="quote">
what do you rev too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">7500-8000</TD></TR></TABLE>
dang....have you encountered any problems yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">nope! Get some ARP rod bolts and you will be fine!</TD></TR></TABLE>
koo... i was told i should balance the ls bottom end so i can rev to 8k rpm,....what do you think?
using stock internals it should already be balanced, unless you replace the Pistons, and then all you have to do is weigh them and make sure they are all within half a gram of each other in weight! If not then go to a machine shop and tell them to balance them! If you have the engine all apart still then go ahead and weigh everything!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">using stock internals it should already be balanced, unless you replace the Pistons, and then all you have to do is weigh them and make sure they are all within half a gram of each other in weight! If not then go to a machine shop and tell them to balance them! If you have the engine all apart still then go ahead and weigh everything!</TD></TR></TABLE>
k.....would b16 pistons( .25 over) be good to run with the 404's or what comp. should i run with?....i cant get a figure everything out with the c-speed calculator so could you inform me on the c/r would be with the p30 and pr3 pistons in the ls motor with oem headgasket and no mill on the head.?
i think to get the c/r up to 11:5 ill use a 2 layer head gasket and maybe get some new valvesm also what about oil and water pump...should i stay with the ls ones?.
sry for all the questions i just wanna build this right
