Idle Jumping no CEL
Old Mar 24, 2005 | 09:36 AM
layed521's Avatar
Default Idle Jumping no CEL
OK, I did a search on this & found nothing that really sounded like my problem, some close though. I have an '89 Civic HB Si with a D16A6, this morning I started driving & noticed my idle was gettin' a bit higher (900-1200 rpm) as I drove, then it started loping, up to 1300-1500 rpm and droping back tp 900-1000 rpm. I shut it off, and restarted it and it was still idling 900-1000 rpm, but steady, then it started loping again. Its not throwing a code either. This is my 1st Honda & I know absolutely nothing about it yet, so any help will be appreciated greatly!
Old Mar 24, 2005 | 09:37 AM
EJ2-Fluffy's Avatar
Default Re: Idle Jumping no CEL (layed521)
Sounds like a vacuum leak. Take the intake arm off and put ur hand up to the throttle body (careful it sucks hard, might hurt a lil). If the car turns off, then you have no vacuum leaks. If however, it doesn't stop then there might be a possible vacuum leak in one of your hoses.
-Jon
Old Mar 24, 2005 | 09:41 AM
layed521's Avatar
I found 1 cracked vacuum hose coming off the carbon canister, fixed it & no change, next.
Old Mar 24, 2005 | 10:18 AM
layed521's Avatar
BUMP! Anyone? BUMP!
Old Mar 24, 2005 | 10:32 AM
Mr_CRX's Avatar
Default Re: (layed521)
Try cleaning out your IACV. They can get gunked up and cause idle problems.
Old Mar 24, 2005 | 10:36 AM
layed521's Avatar
I'll try that, umm, where is it, lol? I think I read somewhere its on the back side of the IM, 2 bolts holding it on, right?
Old Mar 24, 2005 | 10:40 AM
abnaasefmb's Avatar
https://honda-tech.com/zerothread?id=1156086
Old Mar 24, 2005 | 12:04 PM
ef_you_again's Avatar
http://www.hondaswap.com/forum...29790
96hatchBoy
Mar 28, 2013 06:17 AM
erichackett
10
Jul 27, 2010 06:43 PM
mister.wong
29
Mar 10, 2009 03:24 PM
f22abuilder
Feb 7, 2006 09:29 AM
FlatlineEF9
Aug 26, 2004 07:06 PM
