Suspension & Brakes Theory, alignment, spring rates....
dumped on koni yellows, how firm or soft dou set it?
Old Mar 24, 2005 | 08:55 AM
gsr_to_the_MAX's Avatar
Default dumped on koni yellows, how firm or soft dou set it?
i just installed koni's with my sportlines and it dumped my car on the lowest perch setting and i like the way it looks. im set on the stiffest or firmest setting with the konis in the front and its a harsh ride. my friend told me to leave it on the firmest since my front is so low and i dont want my front to be bouncing.
i jsut want to know how firm or soft u guys set ur koni yellows with slammed front. thanks
Old Mar 24, 2005 | 09:04 AM
msmotorsports's Avatar
Default Re: dumped on koni yellows, how firm or soft dou set it? (gsr_to_the_MAX)
Even on the softest setting I doubt you will bottom out as they are still quite stiff compared to other brands. Basically it's user preference when it comes to stiffness unless you are racing.
Old Mar 24, 2005 | 09:06 AM
Marauder's Avatar
That ride is going to suck....they are adjustable, play with it!
My integra was usually set to full soft for daily driving, or 1/2 turn toward firm. Full firm really sucks for a daily driving setup, and only feels good on a smooth road, aka track.
Old Mar 24, 2005 | 09:35 AM
Default Re: dumped on koni yellows, how firm or soft dou set it? (Marauder)
thanks for the info guys.. ill adjust it too a softer setting. better to be safe than sorry. thanks again for giving good feedback
Old Mar 24, 2005 | 09:40 AM
civicross's Avatar
Full soft on f/r on my konis here, daily driven, with an eibach prokit.
Old Mar 24, 2005 | 10:25 AM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_to_the_MAX &raquo;</TD></TR><TR><TD CLASS="quote">i just installed koni's with my sportlines and it dumped my car on the lowest perch setting and i like the way it looks. im set on the stiffest or firmest setting with the konis in the front and its a harsh ride. my friend told me to leave it on the firmest since my front is so low and i dont want my front to be bouncing. </TD></TR></TABLE>
Lowering spring combined with the lowering perch is an open invitation to bottoming and internally damaging the shocks. You are essentially undersprung for the ride height you are at which is not advisable. If you damage the shocks from bottoming, the warranty will not cover it.
If you really like the look and are willing to risk the damage and potential ride issues, I highly suggest that you make sure that you have plenty of bump rubber available. Not just the amount of bump rubberthe Sportlines suggest that you need but more since the car now has less stroke available and is very close to bottoming to begin with. Driving on your bump rubbers is bettter than bottoming iand destroying your shocks on a regular basis. I'd highly recommend against this set-up but if you must, go into it knowing what the risks are and what needs to be done to minimize them. Without it, I'd be greatly surprised if they aren't destroyed from bottoming in just a few weeks or months.
Where you set your rebound damping will have no effect on the bottoming situation so I would suggest for a more livable ride quality, back it off closer to the mid-range so you won't be overdamped and have a really choppy, short cycle ride.
Old Mar 24, 2005 | 11:48 AM
Tyson's Avatar
you really need to get ground control top hats if you insist on running low.
Old Mar 24, 2005 | 12:54 PM
94eg!'s Avatar
#1 Super Guy
Loved
Your original question is kinda like asking someone how much "Pepper" they like on their food. Everybody is different, and it's all about personall preference. Try full soft, and full stiff. Then find a happy medium (that you like). Since your low, your going to bottom out anyways. Remember that shocks are designed to soften up on hard impacts.
Mine are set at 1 full turn from soft (front w/ 400 lb/in springs), and .75 turns from soft (rear w/ 250 lb/in springs). My car is lowered 2.25"-2.5". Rides great (for me)...
***edit*** GC top hats do help
Old Mar 24, 2005 | 01:24 PM
Default Re: dumped on koni yellows, how firm or soft dou set it? (94eg!)
thats is how low my drop is...
dont know if that is slammed to u guys but it is to me
Modified by gsr_to_the_MAX at 3:07 PM 3/24/2005
Old Mar 24, 2005 | 02:15 PM
Vtecfool's Avatar
nice rims fool haha, the drop looks the same as mine. Looks good
Old Mar 24, 2005 | 02:56 PM
slammed_93_hatch's Avatar
actually your not that low, but with the low spring rates your running lee about bottoming out
Old Mar 24, 2005 | 05:19 PM
runvsofkris's Avatar
Default Re: dumped on koni yellows, how firm or soft dou set it? (slammed_93_hatch)
give us some shock and spring pics with the car on the ground....
Old Mar 24, 2005 | 10:30 PM
travis's Avatar
Default Re: dumped on koni yellows, how firm or soft dou set it? (CRX Lee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee &raquo;</TD></TR><TR><TD CLASS="quote">
I'd highly recommend against this set-up but if you must, go into it knowing what the risks are and what needs to be done to minimize them.</TD></TR></TABLE>
Lee's advice is worth taking seriously here.
Old Mar 24, 2005 | 10:59 PM
Default Re: dumped on koni yellows, how firm or soft dou set it? (travis)
maybe ill set it back to the stock perch setting jsut to be on the safe side. thanks
Old Mar 25, 2005 | 02:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by runvsofkris &raquo;</TD></TR><TR><TD CLASS="quote">give us some shock and spring pics with the car on the ground....</TD></TR></TABLE>
and some other pics
Old Mar 26, 2005 | 02:02 PM
Hella_Fresh's Avatar
i guess if you want your car too be low and look good, there are some prices you need to pay (ride quality) but its all up to the drive and what they like.
Old Apr 24, 2005 | 06:45 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: dumped on koni yellows, how firm or soft dou set it? (sXekid)
i ride on FIRM and i love it.. whats a top hat?
Old Apr 25, 2005 | 01:51 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: dumped on koni yellows, how firm or soft dou set it? (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">whats a top hat?</TD></TR></TABLE>
This is-----------------&gt;
Tippyman
14
Oct 29, 2006 10:21 AM
4thgenlude
20
Oct 11, 2004 02:47 PM
00siALLmotor
Aug 28, 2004 05:33 PM
5-SpeedFreak
Dec 3, 2001 01:26 PM
